Traction Advice/wisdom needed for slope operation problems with my PT 1430....
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #1
Hawksledge
Afton, VA
PT-1430
OK ... putting this out hoping for some great PowerTrac owners wisdom from this esteemed group .... Here is my issue: We live on a mountain, so pretty much no flat land around our property. We have access "roads" cut in to allow our PT 1430 to access most of the common areas where we need to work around the house/property, but these access roads are basically dirt/clay fill with some gravel compacted in the mix, and can be at a 25% grade over many sections (so 3ft of rise/fall in elevation over a 12ft level horizontal distance). Now the PT1430 can handle this fine at the start of the work session - including up/down with loaded bucket of rock or pulling a log or trailer. But here is where the problems start .... AFTER the PT has gotten all warmed-up, (oil temp over ~160) when attempting to go up the slope on steep part of the roads - loaded or empty, one or both FRONT wheels will start to spin and dig a nice hole under the tire(s), while the rear wheels will not be turning/spinning anymore. I have been running TRU-POWER AG tread/lug tires. If I stop and let the PT cool for a while, then re-start and make a new run up the hill it will generally do better and make it -- until it gets back to full "warm" again. Naturally, the road conditions can make the situation much worse -- ie: wet and muddy top surface of the road will end-up slipping much sooner, and extremely dry conditions will also allow the tire "digging" to begin a little sooner as well.
SO ... PLEASE ... SUGGESTIONS WELCOME on what options/approaches to consider .... (1) improve the road surface for better traction -- ie: add compacted crusher run? Or, try the grid-cell permeable solutions that can be staked-down on the slope and filled with gravel? Or (2) start making adjustments to the PT 1430 to better manage this issue? -- ie: change in tires?, pressure?, filled-tires?, different/heavier hydraulic oil?, more oil cooling? Or (3) when the PT gets to hot to climb the hill .... stop work for a few hours and go have some cold beverage myself (this option is really hurting my productivity).
Thanks!
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #2
OK, backing up....
What pressure is your tires at? And how old are your tires?
Have you ever used a thermometer to measure your hydrualic oil temp? This is a stupid failing on the PT Design watch. the temp you are reporting is not your hydraulic but your engine temp. You need to use either a laser thermometer or a oil thermometer and dip it into your oil tank under the seat. That will tell us how hot you are running. I assume that when you say you get warmed up that the fan on the engine hood is running?
Did you buy the machine new? Have you re-run any of your hoses?
If a tire breaks free, pressure on that line is reduced so the other tire (which should be your opposite rear) would not spin. or at least not as much.
So lets go to operation. You know that if you want to climb a steep hill you do not mash the pedal down, but let up on the pedal? It is counter intuitive but a hydraulic tractor gets better oomph when the pedal is lightly pressed and not heavily pressed. I tend to mash the pedal momentarily when I start to bog down, then realize that letting it off and "creeping" will get me where I want to go without spins.
Anyway, answer these questions and it will give us all some guidance.
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #3
Hmmm....
That's odd that your fronts would have enough power to break loose with hot oil. Seems you'd have less power with hot oil than cold oil. At least, that's been my experience with my PT425...
Just for giggles, next time it happens, back down the hill, turn around and try backing up the hill and see what happens.
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #4
You also might try bypassing the temperature solenoid for the cooling fan so that it is always on. Upgrading the fan might be an option as well.
I installed a thermometer into my tank cover/tank. As Carl says, it really does help to know what the temps are.
Ken
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #5
So lets go to operation. You know that if you want to climb a steep hill you do not mash the pedal down, but let up on the pedal? ....
That's a good point to remember. And something that's learned either by accident, keen observation, or word of mouth. I figured it out on my hills, but mentioned it here many years ago as what I observed, and that's when the discussion started and I got the explanation as to "why".
For more torque to the wheels, let OFF the pedal. Its extremely counter-intuitive. But its something you learn that becomes automatic after just a few hours of operation once you start paying attention to it.
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #6
Welcome to the club- we are getting jackets made!
25% grade shouldn't be that bad for your 1430. I suspect that it is mostly a traction issue. Compacted 3/4"- would help, as would compacting what you have, if it has enough rock in it.
To WoodlandFarm's point, you do want to have the engine at top rpm, get some momentum, and then just barely step on the forward lever as the going gets tough. I would second MossRoad's suggestion of changing front to back. That often helps me, as does having a wide open throttle, but just barely pressing the "forward" lever. For me, it is mostly a traction issue with the clay and fractured rock. Wet, it is slippery, and dry, it is friable and crumbles, causing the wheels to spin out. There's no great solution that I have found. I suspect that there is perhaps also a leakage issue in the drive pump or motors, maybe due to wear.
Easy does it goes a long way. It almost never makes things any better for me to let the wheels spin. As soon as they do, I back off on the forward lever, and just inch my way through the tricky bits. Easy does it for me. My challenge is pushing the 72" brush cutter up a 30 degree slope of mine.
Let us know how it goes and if any of this is helpful.
All the best,
Peter
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #7
IMO, the expensive but more permanent solution would be to put larger wheel motors on it -- something in the 25-28ci range. That's my plan for mine, reusing the 28.3ci ones from my burned 425, if they are rebuildable...
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #8
3 foot rise in 12 foot run is what, about 14 degrees?
Here's a handy chart....
503807d1490720454-advice-wisdom-needed-slope-operation-pente-slope_-degres-ratio_v1-jpg
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #9
Or you can just do the math on the arcsin(3/12), i.e. the sin[SUP]-1[/SUP](3/12)= 14.4 degrees.
That's partly why I suggested that it should be well within the capabilities of the 1430.
I'm not sure therefore that higher torque motors are the solution.
All the best,
Peter
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #10
MATH! No one told me there was going to be a test today! AAAAAaaaaaaaaaa!!!!!! :laughing:
Sooo.. have some beers and don't think too hard on this...
The green line represents a 45% GRADE.
The red line represents a 45 DEGREE ANGLE.
Can you drive your tractor across a side slope on that red line?
There's been several discussions on TBN in mowing threads, trailer hauling threads, etc... regarding grade VS angle. I don't think a lot of people comprehend or appreciate that Power Trac make a 45 DEGREE slope mower....
Not 45% GRADE......... 45 DEGREES.
That's insane.... :eek:
503858d1490753038-advice-wisdom-needed-slope-operation-45-degree-angle-jpg
Thanks for all the discussion ... nice to have all that internet accessible experience out there! So to answer some of the additional questions raised and background information requested ....
1) I purchased my PT1430 used along with the trailer and a few implements in November 2011. (It started its life in North Carolina with a landscaping company I believe). It arrived with the turf tires. In December 2011, it made a return trip back down to Tazwell VA for a full factory going over and to address some clear maintenance problems. It got a main pump rebuild while there among some smaller repairs and a good check-up from Terry and the crew. Same sort of hill traction issues were present with the turf tires - so decided to try new tires....
2) The current lug tires were a new purchase and installed spring of 2012. Local tire service place had them at close to the rated 20psi pressure. Although traction improved in general vs. the turf tires, the slope issue remained. Tried adjusting the pressure down a good bit - using the advice of sitting on flat concrete surface to achieve maximum contact across the lug tread on the flat hard surface. If my memory holds I think that seemed to be around 8psi. But did not "fix" the slope break-free spinning when hot condition.
3) In 2013 (spring/summer) had another factory return visit and 2 main hoses were replaced - vibration had apparently worn enough to cause a leak where they passed under the operator area foot plates and out to the front end area. Again took the opportunity to have the factory give everything a good look-over while there.
4) As pointed out, I have only been using the standard temp gauge as my guide, and have not installed a meter or spot checked the actual hydraulic oil temp. I will use a laser spot temp meter and keep notes on actual direct oil temp measurements the next opportunity I have to run it long enough to where the slope traction problem kicks-in again.
5) On the operational issues.... yes, I have tried going at all different methods of going light, medium, and full on the pedal and tried climbing both forward and reverse up the steep slope sections, and tired different loading weight options - ie: no bucket, empty bucket, medium fill, and heavy filled. What I have consistently found is when still relatively "cool" I can get up the steep slope sections pretty consistently (as long as the road is not too wet/muddy) in most any configuration. However, even in good road conditions - the worst performance is backwards with loaded bucket; and whenever I get stopped on a steep section - getting started moving uphill can be "iffy" without a tire spinning (progressively worse with warm-up condition). Best approach for me on these steep slope sections is to always come into them with as much speed and momentum as possible and even if a tire breaks loose, can still generally make the climb (until it gets up to the magic temp where it just spins wheels always). As long as I am 1/2 to 2/3 throttle or better (depending on load) - there is never issue with any bogging-down on any light or hard pedal mashing. As a traction and torque note -- we have one short section of asphalt paved driveway that is almost at that same grade - never any traction or power issues on the paved driveway of course - any approach from just creeping with light pedal to full mash down with as much load as I can safely manage is fine on the pavement section.
Hopefully will get good upcoming weekend weather for some outside tractor time and I will report back with more details and specific measurements. Thanks again.
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #12
Well, that's just a weird problem, especially since you don't experience power problems on the paved surface at the same slope. Very weird. I got nothing for you on that. :confused3:
It seems to be purely a traction issue at this point. Especially since you've mentioned it does it with a full bucket. If anything, a full bucket going uphill would put the maximum load on the front tires. Logic says the rears would spin out, not the fronts. At this point, I'd trace every hose from each wheel motor back to the pump and draw yourself a schematic and post it here. Maybe someone with another 1430 will see something that's different than theirs.
I've operated articulated hydrostatic machines since about 1979. Aircraft moving equipment primarily for the first 6 years. I owned an International IH2500b tractor loader, which is a 50PTO HP hydrostatic industrial tractor from about 1990 to about 2007. And I've owned the Power Trac PT425 for 16 years. What all of them had in common was that I am supposed to run them at full throttle all the time. The aircraft moving equipment stated it in the operating manual and so did the International operating manual. The Kohler gas engine in the PT425 is designed to run at 3600 RPMs as well. WHY? Seems wasteful.
Well, its for several reasons. One being you get much better power and response from the machines at full throttle than you do at lower throttle speeds. It not only goes better at full throttle, it stops better at full throttle. And its less stressful on the pumps at full throttle. It generates less heat under load at full throttle. And it dissipates more heat under load at full throttle. With the Kohler gas engine, its designed to operate at 3600 PRM and that provides maximum air flow through the cooling fan as well.
The only reason I mention this is because you mentioned 1/2 and 2/3 throttle settings. I'm gonna assume you've tried it at full throttle many times.
Very perplexing, especially in that it occurs after its warmed up. Very perplexing. :confused:
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #13
the temp reading is going to say a lot.
And just to confirm, if the bucket is empty you go up and down no issue, right?
I run 6PSI... 2lbs does make a difference. Also, you might want to try chains...
One other thing you could do. Get the beast hot, then jack it up.. start it and run the treddle forward and back. All wheels should rotate in unison and at the same speed.
Oh, those drive hoses you replaced fail avery few years for me . I finally but a hose protector over the front tunnel lip to stop the hoses from rubbing.
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #14
No. He said bucket full or empty. He even said no bucket at all.
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #15
5) On the operational issues.... yes, I have tried going at all different methods of going light, medium, and full on the pedal and tried climbing both forward and reverse up the steep slope sections, and tired different loading weight options - ie: no bucket, empty bucket, medium fill, and heavy filled. .....
Here's where he mentioned it.
I'm stumped.
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #16
My roof has a 45° slope so every day I get to look at what the PT1850 is rated for and shake my head in amazement.
Ken
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #17
I don't know if this is revelant but my 422 would have less torque when hot. It came with 5w30 transmission oil. I changed it to 15w50 Mobil 1 synthetic oil. It made a significant difference. I do keep my 422 in a heated garage.
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #18
Ok. If I were teching this.
First lower tire pressure
Second. Confirm cooling fan is runnung
Third. Figure out true hydraulic temp
Fourth. Jack tractor up while hot to confirm tire rotation
Fifth. Check hydraulic lines confirm wheel drainage works
It gets expensive after this
Use hydraulic pressure gauge to check system
Replace oil with synthetic oil
Wheel motors tested
Tram pump tested.
The one thing is that PT expiremented with weird wheelmotor plumbing so if you do give a quick sketch it would help
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #19
Two thoughts:
1) I do think that it is a traction issue, and that the hot vs cold has more to do with how many times you have gone over the same piece of soil. My technique has been to just feather the accelerator to keep the engine speed up and the spinout to a minimum. (It's never zero on steep dry soil for me. The mix of dry clay and gravel/rock seems to be too friable.)
2) FWIW: I did change my oil from 10W40 dino oil to 15W50 pure synthetic and I saw no change in behavior for my steep hill spinouts/loss of torque.
All the best,
Peter
   / Advice/wisdom needed for slope operation problems with my PT 1430.... #20
I agree that it is likely the repeated passes over the same area. I have some 30° areas that are loose shale and clay and each time i go over the same area, my wheels will spin more than the last. Then rain/dew helps things adhere again until the next time I do multiple passes. So I try to use different trails as much as possible for each trip. This is also true with my wet clay areas where multiple passes will rip off the top layer of grass after a few runs over it and leave a mess.
If you have an option to do an angled path that is less steep, that would likely help. I also am always looking for tree die offs that lend themselves to new trails where the trees used to be. I hate cutting down live trees but I really should get into the practice of thinning my woods as well.
Ken
Two thoughts:
All the best,
Peter
206707 (A58375)
206707 (A58375)
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2009 CATERPILLAR AP1000D ASPHALT PAVER (A60429)
2009 CATERPILLAR...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
