Advice needed regarding Grapple
/ Advice needed regarding Grapple #21
Is that a basketball goal pole? I am trying to imagine a basketball hoop in the middle of a field, placed there 20 years ago...
/ Advice needed regarding Grapple #23
Nope, just an old broken off pipe fence post that was there when we bought that place.
Lots of used 2-3/8" and 2-7/8" pipe from the oil fields available around here.
Here is some with concrete still on the pipe, hanging on the 48" block forks:
/ Advice needed regarding Grapple #24
What I have done in the last year is picking them up with the subsoiler and pushing with a bucket . I had a tc 30 ath the time . Maybe if I break them loose and then pick them up with the grapple it would work. This tractor has twice the power
Is this worth a look?
/ Advice needed regarding Grapple #25
/ Advice needed regarding Grapple #26
I feel like a stump bucket would create a much bigger hole then a grappler. We are talking about a small spruce stump here, they are pretty easy to pull out... I am assuming Op's replant every row once the stump is gone ?
/ Advice needed regarding Grapple #27
A stump bucket does make a big mess if you’re digging a bigger stump. If you’re only digging a small spruce stump you can flip it out of the ground with the teeth without digging any hole at all. Most people wouldn’t consider digging a large stump like the stump bucket is capable of with a grapple.
/ Advice needed regarding Grapple #28
I have an American Attachments Root Grapple on 50hp. I think their narrowest (Economy Series) is 60 inches in Root or Rake. No issues as far as strength from me.
IRanch High-End Tricycle (A64119)
IRanch High-End...
159116 (A60430)
159116 (A60430)
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2021 Case TV450B (A64126)
2021 Case TV450B...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
IH Farmall B Tractor (A66285)
IH Farmall B...
