Advice needed regarding Grapple
/ Advice needed regarding Grapple #21
Is that a basketball goal pole? I am trying to imagine a basketball hoop in the middle of a field, placed there 20 years ago...
/ Advice needed regarding Grapple #23
Nope, just an old broken off pipe fence post that was there when we bought that place.
Lots of used 2-3/8" and 2-7/8" pipe from the oil fields available around here.
Here is some with concrete still on the pipe, hanging on the 48" block forks:
/ Advice needed regarding Grapple #24
What I have done in the last year is picking them up with the subsoiler and pushing with a bucket . I had a tc 30 ath the time . Maybe if I break them loose and then pick them up with the grapple it would work. This tractor has twice the power
Is this worth a look?
/ Advice needed regarding Grapple #25
/ Advice needed regarding Grapple #26
I feel like a stump bucket would create a much bigger hole then a grappler. We are talking about a small spruce stump here, they are pretty easy to pull out... I am assuming Op's replant every row once the stump is gone ?
/ Advice needed regarding Grapple #27
A stump bucket does make a big mess if you’re digging a bigger stump. If you’re only digging a small spruce stump you can flip it out of the ground with the teeth without digging any hole at all. Most people wouldn’t consider digging a large stump like the stump bucket is capable of with a grapple.
/ Advice needed regarding Grapple #28
I have an American Attachments Root Grapple on 50hp. I think their narrowest (Economy Series) is 60 inches in Root or Rake. No issues as far as strength from me.
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
Caterpillar TL1055D (A62177)
Caterpillar...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
