Adjustable side link stuck
/ Adjustable side link stuck #1
TigerfaninAR
Central Arkansas
Kubota B2320 FEL, MMM
New to me tractor (used B7300) and the adjustable side link is stuck like nothing else. The adjustable part that lets you swing the arms wider was stuck but after a little oil and elbow grease all works well. Didn't work for the side link. How forcefull can I be? Any product that works better than others? Thanks
/ Adjustable side link stuck #2
Soaking in PB blaster may help along with a little tapping from a hammer. If you have a torch try heating it up before the PB stuff to see if that will break the bond.
/ Adjustable side link stuck #3
If you are talking about the turnbuckle system, if they stay frozen and need to be replaced, you might consider replacing them with the telescopic stabilizers. I changed the turnbuckle system out on mine because I had bent a couple of the bolts and the telescopic system has the benefit of much easier adjustability and it holds the lower control arms spread apart at whatever width you set at instead of them collapsing in. I also have the Pats Quick change system, so I no longer have to use the spreader bar to hold mine apart when I am hooking up implements.
Stabilizer
Thanks :thumbsup: Will try the PB before spending the money on the telescopic system, but that sure looks nice.
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
2017 Ford Fusion Hybrid Sedan (A64557)
2017 Ford Fusion...
VOLVO P7110 ASPHALT PAVER (A65053)
VOLVO P7110...
2010 FORD F750 BUCKET TRUCK (A65054)
2010 FORD F750...
SARLO (A64557)
SARLO (A64557)
2020 Freightliner CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 Freightliner...
