Adjustable side link stuck
/ Adjustable side link stuck #1
TigerfaninAR
Central Arkansas
Kubota B2320 FEL, MMM
New to me tractor (used B7300) and the adjustable side link is stuck like nothing else. The adjustable part that lets you swing the arms wider was stuck but after a little oil and elbow grease all works well. Didn't work for the side link. How forcefull can I be? Any product that works better than others? Thanks
/ Adjustable side link stuck #2
Soaking in PB blaster may help along with a little tapping from a hammer. If you have a torch try heating it up before the PB stuff to see if that will break the bond.
/ Adjustable side link stuck #3
If you are talking about the turnbuckle system, if they stay frozen and need to be replaced, you might consider replacing them with the telescopic stabilizers. I changed the turnbuckle system out on mine because I had bent a couple of the bolts and the telescopic system has the benefit of much easier adjustability and it holds the lower control arms spread apart at whatever width you set at instead of them collapsing in. I also have the Pats Quick change system, so I no longer have to use the spreader bar to hold mine apart when I am hooking up implements.
Stabilizer
Thanks :thumbsup: Will try the PB before spending the money on the telescopic system, but that sure looks nice.
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
2004 JOHN DEERE 750C LT SERIES 11 CRAWLER DOZER (A65053)
2004 JOHN DEERE...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A64553)
2025 Wolverine...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
Wooden rocking horse (A64557)
Wooden rocking...
