Additional lights on 2305 ROPS
/ Additional lights on 2305 ROPS #21
Wow, I never thought of that, KennyD! Seems there are a couple ways of going about/around this. #1 would be to do exactly as you did, and have a dedicated switch. Knowing me, this would increase the risk of leaving them on accidentally and draining the battery. Perhaps I could locate a wire that activates when the key it turned, but what if I want them on for a short time when the tractor is off? :) I could always go with LED instead of the 12V/55W halogens I got. I went with the halogens for the simple reason that LED's produce little to no heat in this size. Since much of my night work will be on winter evenings (which are long and dark in Maine) the halogens produce heat that will keep the light from ice/snow buildup. So, I could always put LEDs in the hazzard and headlights to reduce the draw. Seems this isn't as simple a choice as I initially thought. lol
This is all very helpful information!!!
Mc, LEDS do run cooler but I'm not sure where or how this urban myth came about ( I think it has something to do with some NW county getting their LED stop lights snowed over in winter) but LED's throw out enough of heat to keep them from being snowed over short of a blizzard. They'll always throw light enough for you to see in a snow storm.
/ Additional lights on 2305 ROPS #22
Just a thought .... you could install a single-pole-double-throw switch in the line that runs to the headlights. Then run a wire from that to the headlights and another to the new work lights. That way, the headlight switch will control either set of lights you want to use at a given time but not allow both to be on at the same time to prevent over amp usage.
I like it, Qapla! Best of both worlds! And in case anyone wondered, I absolutely did blow the 10 amp fuse that is stock in the work light line. :)
/ Additional lights on 2305 ROPS #24
MC, I had a similar problem like yours. I have a dynamo that only produces 15 amps. What I did was added a toggle switch for two forward facing LED lights, and another switch for 2 backward facing LED lights. This way I can control the headlights, the forward facing, and the rear facing all independently. This all works nicely and doesn't over push my dynamo. Additionally, the LED's throw just enough heat to melt any snow. I am in Connecticut and we certainly get our fair share of cold and snowy winters.
Ok, Scotty. Maybe I was given incorrect info. CT is pretty similar to ME in that regard. :)
Thank you all for your help and advice on this project!!! I got the lights hooked up and used them one evening last week. All went well until both lights vibrated loose Thurs. and fell off. I put some rubber bushings in that should help with that problem. Below are some pics! Would love to hear your thoughts and input on the final product! :)
John Deere 2305 w/ 200CX fel & quick hitch power broom.
/ Additional lights on 2305 ROPS #28
Looks good. Are they in your eyes at all when you look back to back up?
Not really, monroe. Especially since I blew another fuse when I was tightening the nuts over the bushings tonight. Lol
John Deere 2305 w/ 200CX FEL & quick hitch power broom.
/ Additional lights on 2305 ROPS #30
From what you said about the nuts vibrating loose I take they are standard type metric or SAE. Have you thought of replacing the regular nuts with ones with the locking plastic inserts. I have had good results with using the plastic lockers in high vibration areas.
I hadn't thought of that, Gator. I'll see if I can find some! I'm also having wiring problems since the wires and bolts go through the same pre-drilled hole in the rops. Any ideas?
/ Additional lights on 2305 ROPS #33
gator is describing nylock nuts which is a good choice, available at any hardware store. I can't visuallize what is going on with the wires but any of these should protrude through the rops without a chance for pinching. If you need a new hole for the wire to pass through the rops might make it big enough to fit a rubber grommet.
Ahh...see, the bolt goes from the lights, through the bottom hole with the wires beside it, then out the top hole, while the wires stay inside the rops. I didn't dare drill a second hole for wires because I thought it would weaken the rops. Is a small hole for wires ok to drill? That would be ideal!!
/ Additional lights on 2305 ROPS #35
That's exactly what I did for mine. That extra hole won't hurt anything, but either put some flexible conduit around the wire where it goes into the ROPS, or put a rubber grommet in the hole to avoud chafing the wire.
Sent from my LGL35G using TractorByNet
/ Additional lights on 2305 ROPS #36
I drilled mine as well, two small 1/4" holes will be OK. If you looked at the older post I linked above you'll see that I drilled mine a few times.
2018 GMC Sierra 1500 Crew Cab Pickup Truck (A66736)
2018 GMC Sierra...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
213135 (A64276)
213135 (A64276)
2010 INTERNATIONAL WORKSTAR 7400 BUCKET TRUCK (A67714)
2010 INTERNATIONAL...
2016 Nissan Frontier Crew Cab Pickup Truck (A66736)
2016 Nissan...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
