Adding rear remote and 3rd function FEL Kubota L4240
   / Adding rear remote and 3rd function FEL Kubota L4240 #21
Steering either has it's own dedicated pump or a flow divider, depending on the manufacturer. The 10gpm rating is what is avalible to your impliment circuit & relevant to the conversation. The 5gpm of steering flow gets routed elsewhere one way or another before you care about it.
   / Adding rear remote and 3rd function FEL Kubota L4240 #22
No clue on "Y". Give use a link so we can look up the item. Flow will be throughout the valve body. 12 gpm will be fine given your 10 gpm available flow. No clue if the power beyond plug is included. Check before you buy. Get hoses at whatever size the basic flow path already has for the supply/PB circuit. Impliment hoses can be smaller most of the time since you are really not using much fluid. Except if you want to run a motor or log splitter.
Good to know 12gpm looks good. I don't want any kind of heat increasing restriction. I'm asking this tractor to do a lot, I understand that. But for now, it's what I own, so it's what I'll use. I'm not the type to trade up all the time. I use stuff until it's used up.
   / Adding rear remote and 3rd function FEL Kubota L4240 #24
If you did ever trade up, the valve stack and QDs could be moved to a new machine. A lot of the setups have a mounting plate on the ROPS. The valves sit where they can be ran with the right hand and the QDs face the rear- all in one package. Undo 4 hoses and 2 wires and it’s moveable!
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A57453)
1995 Chevrolet...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
Service Truck (A59230)
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
