Adding a temperature gauge to 2210
/ Adding a temperature gauge to 2210 #1
passgas55
I was looking over my 2210 to add a temp gauge and the only place I see a pickup point is where the temp light indication switch is. I would like to keep the light and I prefer not to add a tee in the radiator hose. Am I missing a place where I can add a temp probe? Thanks
/ Adding a temperature gauge to 2210 #2
I haven't done it, but I believe they normally install a "T" where the existing temp sensor is and run both from that.
/ Adding a temperature gauge to 2210 #3
A tee does not usually work too well on a temp gauge. The sensors for both will need to be down in the water and it's not going to be easy to do that with a tee.
/ Adding a temperature gauge to 2210 #4
"T" would not work on mine. Neither sensor would see the true temperature. Has to be down in the water.
/ Adding a temperature gauge to 2210 #5
yup - it's one or the other....I went with the guage.
Do a search and you 'll find the right part you'll need.
However - for the oil pressure - you can oput a tee in-line nad end up with both the dummy light AND a guage....
have fun
mike
I will add a tee in the radiator hose one day. I guess I just wanted my cake and eat it too.
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
Westfield Gravity Wagon Auger (A66408)
Westfield Gravity...
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
