Adding a temperature gauge to 2210
/ Adding a temperature gauge to 2210 #1
passgas55
I was looking over my 2210 to add a temp gauge and the only place I see a pickup point is where the temp light indication switch is. I would like to keep the light and I prefer not to add a tee in the radiator hose. Am I missing a place where I can add a temp probe? Thanks
/ Adding a temperature gauge to 2210 #2
I haven't done it, but I believe they normally install a "T" where the existing temp sensor is and run both from that.
/ Adding a temperature gauge to 2210 #3
A tee does not usually work too well on a temp gauge. The sensors for both will need to be down in the water and it's not going to be easy to do that with a tee.
/ Adding a temperature gauge to 2210 #4
"T" would not work on mine. Neither sensor would see the true temperature. Has to be down in the water.
/ Adding a temperature gauge to 2210 #5
yup - it's one or the other....I went with the guage.
Do a search and you 'll find the right part you'll need.
However - for the oil pressure - you can oput a tee in-line nad end up with both the dummy light AND a guage....
have fun
mike
I will add a tee in the radiator hose one day. I guess I just wanted my cake and eat it too.
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
20ft Driveway Gates (A65579)
20ft Driveway...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
