Above Ground Pool Install
   / Above Ground Pool Install #31
Filters...I have a hot tub and was researching filters. I came across ECOsmart pool and spa systems. This is totally a chemical free system. It comes with a 5 year warranty and 60 day money back guarantee.
I have had it installed now for about 7 months. It been working great. Nothing really that I have to do. Check the water once a week and maybe flip a switch. I figure I will pay for the system in chemical savings in two years.
Check them out on the Internet.
Wally
   / Above Ground Pool Install #32
archerynut said:
Heres what I remember about filters:
Sand - by far the easiest and least costly. You may only have to change the sand every other year depending on pool conditions. However if you do have an algae problem the sand filter is the worst for cleaning it up. The sand filter catches the largest particles and lets the smaller ones slip by.
Earth a.k.a. - DE - The most efficient filter at catching fine particulates. The is the filtering system if you want the cleanest water. Also seems to be the most work and fraught with the most problems. The bonus to the system is that you change the filter medium when you backwash the filter. You start "almost fresh". This filter will clean up a pool the fastest. Most amount of maintenace. More costly to purchase and most costly to maintain.
Cartridge - many new advances in this area in the past years. The newer cartridge filters have better elements than ones in the past. Some systems can even use earth with the cartridge. Will pick up most particles but not as small as earth filters. More expensive to buy and maintain, the filter elements can get expensive although the new ones are a lot more durable than the older paper elements. Not too much down time if you have a spare element, as you clean one you put another in to run.
The biggest determining factor in whether or not you will have clear clean pool are water chemistry, proper sanitation, and proper filtration. If you have a choice buy a filter one size bigger than you need, it will work better and longer before cleanings are needed. The more that you run the filter the less chance for algae growth. Running the filter 24/7 is not unheard of when the weather is really hot around here.
Very nice comparison of different filter types.
I personally went with the DE filter. To me the maintenance of the DE filter is much easier and cheaper. I'll buy 25 lbs of material and it will last 2 years. Total cost $18/2 years.
Here are the current prices for the systems I looked at when I replaced mine a few years ago.
DE Filter
$260 and DE media at $18.00/25lbs (lasts 2 years)
Sand Filter
$229 and replacement sand $90.00/100lbs
Cartridge Filter
$329 and replacement cartridge $89.00
With the DE filter, when the pressure raises 5lbs or so, shut the unit down and bump the handle on the filter and repeat in 2 weeks or so. Replace media when the pressure does not drop to pre-charge pressures (approx 3 times a year at 4lbs of media each time).
These are just my observations and someone elses may be different as I'm in Ohio and the season is 4 months long if we're lucky.
   / Above Ground Pool Install #34
txdon said:
Yes I have one of those, similar anyway. Here in our neck of the woods, just make sure it's not being used during the night as it will actually lower the water temp when the sun goes down. It might be different in TX though, depending on your outside temps. I used a series of hoses and bypass valves so I could bypass it on cloudy days or at night.
The plastic is very thin though and you may have to close off a tube when/if it springs a leak.
I have 2 leaks in mine right now so I probably won't connect it this year. When the sun is shining brightly on it, it will send water 10-15 degrees warmer into the pool. Try to locate it for full sun exposure most of the day, angled like in the picture. Mine is vertical and does not do as good as it could.
   / Above Ground Pool Install #35
Inspector507, I was wondering what to do with it during August, now I know - run the water through it at night to cool off the pool. Last year we turned off the cabin's electric hot water heater during the month of August. Thanks for the Idea!
   / Above Ground Pool Install #36
KubotaSteve said:
I prefer sand filters because of cost. The cartridge filters are less maintenance but cost more to maintain because you are constantly changing the filters. The sand filters aren't that much maintenance but you do have to backflush the pool every so often. The worst part is moving the filter inside each year with a 150 pounds of sand it in, but the way I have my setup, I just pull up to it with the tractor and slide it in the bucket.
Just my two cents.
Why do you have to move the sand filter inside? I just drain mine and leave the drain plug out all winter, and move the valve to the winter position. It has lasted 10 years, so far.
   / Above Ground Pool Install #37
Inspector507 said:
Sand Filter
I just picked up #20 sand in 50 pound bags for $12.50 a bag at our local pool store on Friday.
   / Above Ground Pool Install #39
i have had a pool for 28 years de filter and if you have the ph in the water good the water should be clear far from rocket science just be aware of pool companies, they love to sell you all kinds of stuff to put in your pool to keep it clear and dont work, all i do is shock it first time in the spring adjust the ph add algaecide and forget it get an automatic chlorine dispenser well worth the money add chlorine once a week and your good to go
   / Above Ground Pool Install #40
i have had a pool for 28 years de filter and if you have the ph in the water good the water should be clear far from rocket science just be aware of pool companies, they love to sell you all kinds of stuff to put in your pool to keep it clear and dont work, all i do is shock it first time in the spring adjust the ph add algaecide and forget it get an automatic chlorine dispenser well worth the money add chlorine once a week and your good to go the cost for me to run my pool is abot 100 dollars a year
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
2009 MACK CXU613 DAYCAB (INOPERABLE) (A50854)
2009 MACK CXU613...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
Walking Floor Trailer (A50322)
Walking Floor...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
