8N Draft Position control
/ 8N Draft Position control #1
Kevin F
8N with TO20 back half
I am 100% positive that this has been discused.
Thank you all for your valuble time.
I have a 1939 8N and it will not hold position or draft.
If i have an attachment on the 8N and is in the up position, when 8N is shut off the implament will drop/bleed off.
Replaced relife valve.
Is pump bad?
Not sure what it is call the spring loaded center mount tip ans tilt screw bar.
I know it has a recamended preload, could that be whats wrong?
/ 8N Draft Position control #2
Its probably the piston seal or bore. The original ones were just a metal ring similar to an engine piston ring.
Upgrade kits actually use an o-ring. ANd they do hold well if the bore isnt scored.
The cylinder is on the underside of the top cover that the seat is bolted to.
Also, if you have a 1939, it is NOT an 8n
My 8N is an odd duck engine says 8N on it but the top cover is a TO20.
I replaced the cylinder and piston under the top cover with the new o-ring style.
I have researched and they did manufacture TO/8N hybrid when parts got hard to get.
/ 8N Draft Position control #4
8n didn't come around til 1948. So if it is indeed a Ferguson/N-series hybrid.....it would be a 9n variant if your date is correct.
Along the way, someone may have replaced the engine.
Or it could just be a Frankenstein tractor all together. Could have originally been a 9n that someone busted the rear axle and dropped a to-20 axle on.....then later on blew an engine and swapped with a 8n engine.
/ 8N Draft Position control #5
But regarding the issue at hand, when did you replace the piston and o-ring?
There eis no relief valve in play nor the pump when it's off. Could be something in the valve
Replaced everythin under top cover approx two years ago.
/ 8N Draft Position control #7
Didn't ever fix the issue or has it been a problem for the last two years
/ 8N Draft Position control #8
No same problem as before replacing cylinder
No
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2025 Swict 66in. Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2003 Ford F-350 Flatbed Sprayer Truck (A61573)
2003 Ford F-350...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
