8N Draft Position control
/ 8N Draft Position control #1
Kevin F
8N with TO20 back half
I am 100% positive that this has been discused.
Thank you all for your valuble time.
I have a 1939 8N and it will not hold position or draft.
If i have an attachment on the 8N and is in the up position, when 8N is shut off the implament will drop/bleed off.
Replaced relife valve.
Is pump bad?
Not sure what it is call the spring loaded center mount tip ans tilt screw bar.
I know it has a recamended preload, could that be whats wrong?
/ 8N Draft Position control #2
Its probably the piston seal or bore. The original ones were just a metal ring similar to an engine piston ring.
Upgrade kits actually use an o-ring. ANd they do hold well if the bore isnt scored.
The cylinder is on the underside of the top cover that the seat is bolted to.
Also, if you have a 1939, it is NOT an 8n
My 8N is an odd duck engine says 8N on it but the top cover is a TO20.
I replaced the cylinder and piston under the top cover with the new o-ring style.
I have researched and they did manufacture TO/8N hybrid when parts got hard to get.
/ 8N Draft Position control #4
8n didn't come around til 1948. So if it is indeed a Ferguson/N-series hybrid.....it would be a 9n variant if your date is correct.
Along the way, someone may have replaced the engine.
Or it could just be a Frankenstein tractor all together. Could have originally been a 9n that someone busted the rear axle and dropped a to-20 axle on.....then later on blew an engine and swapped with a 8n engine.
/ 8N Draft Position control #5
But regarding the issue at hand, when did you replace the piston and o-ring?
There eis no relief valve in play nor the pump when it's off. Could be something in the valve
Replaced everythin under top cover approx two years ago.
/ 8N Draft Position control #7
Didn't ever fix the issue or has it been a problem for the last two years
/ 8N Draft Position control #8
No same problem as before replacing cylinder
No
60'' skid steer bucket (A61567)
60'' skid steer...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A60352)
2017 Gravely...
flatbed trailer 24ft (A56857)
flatbed trailer...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2008 CHEVROLET EXPRESS VAN (A60736)
2008 CHEVROLET...
