8N 12V Conversion - Points issue
/ 8N 12V Conversion - Points issue #21
if square coil only, then get the 2.5 ohm version and use it with the oem dash resistor
Yes, this dizzy is the sqaure type. What I need to know is where the one wire on the back side of this dizzy goes
/ 8N 12V Conversion - Points issue #22
that post is not on the cap but on the coil itself. that is the wire that comes from the key switch, after passing thru the resistor.
you need to get a master parts catalog and a service manual.. will help you id parts.. make it easier to communicate..e tc. diagnose.. etc..
/ 8N 12V Conversion - Points issue #24
front mounts were 39 into the early 50's
2013 Mercedes-Benz GL450 AWD SUV (A61574)
2013 Mercedes-Benz...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2018 Takeuchi...
