Busted 8N
/ Busted 8N #21
Found this on another forum.
1 always towards the radiator.
FO 1243
CCW
Upper left looking from the front... 11 o clock..
2 left bottom.
4 bottom right.
3 upper right.
Standing in front of the tractor looking at the seat.
/ Busted 8N
Have you replaced the ignition switch? After time the switch can start acting intermittently. It will test "good" with a static continuity test but then during operation cut out intermittently. You can bypass the switch altogether by disconnecting from the leads and directly connecting the wires together and then starting the tractor to see if things improve.
My neighbor who's a retired mechanic tested the ignition switch for continuity and jumped the connections. No change. I will reconfirm with him. Thanks
/ Busted 8N
I HAD SOME PROBLEMS WITH ENGINE PERFORMANCE ON A 9N.AFTER REBUILDING AND STILL THE SAME. I DISCOVERED IT HAD A AFTER MARKET COIL AND THE RESISTER TO THE COIL WAS JUMPED. REPLACED WITH FORD PARTS AND IT RAN WELL. DOES THE COIL MATCH THE 6 OR 12 VOLT BATTERY? NEG. OR POSITIVE GROUND?
I bought the tractor from a guy who restores 8N's and he rewired the entire tractor and did a professional 12V conversion with the kit offered from Redbelly Tractors - Restorations | Just8N's.
The alternator has an internal resistor and the coil is an automotive 12v design. Not knowing how to test the coil properly, I bought a new 12v coil from tractor supply and replaced it. This didn't fix the problem.
I'm aware that some 12V conversions are hack jobs and some don't replace the coil with a 12V design, but my conversion seems to be done right and it ran perfectly for two years.
/ Busted 8N
FO 1243
CCW
2 left bottom.
4 bottom right.
3 upper right.
Good copy on all that. Thanks
/ Busted 8N #25
A mechanic with hands on can make more headway in 30 minutes than a dozen can in a week on the net. You might think about paying him to fix it and save yourself some grief.
/ Busted 8N
Yea true, I'm just hard headed and like to fix things myself. I know if I take it to a mechanic it'll be some little thing that I missed and I'll be kicking myself. But the fields haven't been mowed in a couple months and you're right I may be better off just paying some one to fix it.
/ Busted 8N #27
My brother and I had an 1800 Oliver given to us,previous owner said his mechanic friend told him the motor was blown. Ran but barely missing and popping, could only get it started by pulling it. Did most of everything you have stated and ended up buying a brand new carb. Long head ache short the coil was bad and the new one was also. Bought a second new coil and the old beast runs like a top. Not sure what the chances of that happening are but figure I would mention for what it's worth. BTW both coils showed spark when we checked.
/ Busted 8N #28
I've read the first of three current pages and can't wait to see how this turns out.
/ Busted 8N #29
Now, I've read all of the commentes and no resolution. :irked:
Serioisly, good luck.
/ Busted 8N #30
Far more often than it should. Points and coil ignition hasn't been used on cars for over 40 years so quality control during manufacturing is almost non-existant today. Unless a person know's how to test components they have no way of knowing which part was bad to begin with and if replacement is bad.
/ Busted 8N #32
I would NOT recommend using starting fluid to check for intake leaks. You can actually spray water on the areas under suspicion for greater safety. Anything that gets sucked in where it shouldn't will change the sound. I have used carb cleaner or WD-40 but never ether.
/ Busted 8N #33
OK, I'm going to go way out into left field...because it sounds to me like you've hit all the normal things to look at and without any change.
What if the intake valves to those two cylinders are simply not opening up to allow new charge to come in? Something might have happened to the cam, or valve lifters, or rockers, or the valve clearance. And if you only do a compression test you aren't going to pick that up.
So it it were me, I would take off the valve mechanism cover - not sure which cover it is on the 8N, but it's where you adjust the valve clearance. And then I would crank the engine over and physically watch to see if all the valves are opening up when the engine is cranked over.
If you want to crank it by hand, just take out all the spark plugs and you might be able to turn it with the fan or a wrench on the front crankshaft nut.
And if you don't know the 8N valve sequence then just follow this old rule which works for any engine:
For the valves on any cylinder, adjust the intake when the exhaust valve is just beginning to open....and adjust that cylinder's exhaust valve when the intake has just finished closing. Those are the points of maximum clearance.
Enjoy,
rScotty
/ Busted 8N #34
"I'm about to push the tractor off a cliff and go buy a new kubota."
Even if you fix your problem a new kubota (or any other color) might be tempting. I replaced my 8n which I had owned for 30 years, with a new MF a few years ago. The difference in what I can do with the new tractor is amazing, not to mention how much easier it is on my body to operate it. Keep the 8n as a pet and get something new. Hey we all need someone to ask us what to get so we can help you spend your money:D
/ Busted 8N
Enjoy,
rScotty
Thanks for the insight. When I pull he manifold, I'll pull the valve covers and inspect them for correct operation. I have a service manual and will adjust to spec.
/ Busted 8N
LOL, you're so right. I am going to buy a new Kubota L or Yanmar YT for my eight acres. I bought the property two years ago and the 8N as a short term stop gap until I could afford a new one. The 8N will be for wagon pulling duties and I'll put the new one to work doing everything else.
But first things first, gotta get this 8N running.
/ Busted 8N #37
Since you are still trying to fix this thing the least you should do is stop throwing things at it and begin a systematic approach. You have repeatly been told to pull plug wires but I don't se where you reported the results of pulling wires. In your original post,you said but it stills runs like its firing on two cylinders.
Is it dead missing on two cylinders? (you can tell by removeing 1 plug wire at a time). Or is it simply running so bad it sound's like only two are hitting? There's a huge difference and each requires intirly different troubleshooting methods.
/ Busted 8N
I'm actually on a business trip right now but will be back in town soon to verify the plug wire routing. Thanks for your advice.
/ Busted 8N #39
Okie Dokie,let us know what you find with wire routing. Hopefuly a couple just got crossed and that will fix it. If not,see if pulling one at a time make's a difference in how it runs. Travel safely.
/ Busted 8N #40
If it wasn't in the plug wires, I'll bet you find it when you look how the valves are working.
And I hear you on modern tractors. We bought an old - new in 1958 ! - JD as our "gap filling" tractor and know of two friends who bought old MFs much like the 8N. And another who has an even older massey Harris!
Here's the thing....ALL of us have newer Japanes styel 4wd loader tractors now that we use on a daily basis...but ALL of us kept the old "gap-filling" tractors for just the same reasons you put forward - To pull a wagon and be a backup. We all still have them! After all, those old american-made farm tractors wouldn't bring anything on the used market, but every one of them runs and works just fine. And probably for another 50 years, too if we can find decent gas to put in them. They are family members, now.
Hint: If your old gas tractor sits for months or longer, put aviation gas in the tank. You aren't using much gas anyway, and av gas is the best quality i absolutely no water or alcohol in it.
rScotty
ALLMAND MAXI-LITE II V-SERIES (INOPERABLE) (A68842)
ALLMAND MAXI-LITE...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2014 Ford Escape AWD SUV (A66738)
2014 Ford Escape...
2010 CHEVROLET TAHOE SUV (A66091)
2010 CHEVROLET...
2019 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65056)
2019 CATERPILLAR...
Set of 4 Unused 12-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
