Busted 8N
/ Busted 8N #1
Tractorable
Veteran Member
Marshall, Va
Tractorless, 2019 Toyota Tundra, 1980 Toyota Land Cruiser FJ40
1952 Ford 8N, side mount distributor, 12V conversion.
So I consider myself to be a pretty good shade tree mechanic but I'm having trouble getting my 8N to run. It ran great for two years but now I'm having issues.
I'm getting fuel to the carb and a spark at all four cylinders but it stills runs like its firing on two cylinders. I've done everything I know how to do except to tear into the motor and start replacing manifold and head gaskets.
This is what I've done so far:
- New battery and battery cables
- New coil
- Drained fuel tank and replaced fuel with fresh gas
- Confirmed good fuel flow by removing drain at bottom of carb
- Rebuilt carb
- removed, cleaned, adjusted distributor. New points, condensor, rotor, cap
- checked continuity in distributor in six different places, all good
- new plug wires
- confirmed spark at all four cylinders
- opened spark plug gap to nearly 1/4" and still got spark
- removed and inspected governor, looked fine
- engine oil is clean and full, no sign of coolant/oil mixing
- compression is strong: 120psi, 120, 118, 115 - 90psi minimum
- verified TDC and timing mark on flywheel, points just opening at 4 deg BTDC on #1 cylinder
I'm about to push the tractor off a cliff and go buy a new Kubota.
Should I tear into the motor and replace manifold and head gaskets?
Any other ideas?
/ Busted 8N #2
Wow! I was gonna suggest compression test, but you hit that towards the end. It’s a head scratcher...
/ Busted 8N #3
Have you checked the firing order and made sure the correct spark plug wire is on the correct spark plug?
/ Busted 8N
Yes, I double and triple checked that. 1, 2, 4, 3. I can do it backwards and in my sleep now.
/ Busted 8N #5
It looks like you replaced everything electrical except the spark plugs. Sometimes I've had a plug that would fire in open air, when you test for spark, but wouldn't fire under compression. Might try new plugs first, it's fairly cheap, and with those compression readings I don't think you'd find anything amiss in a teardown.
/ Busted 8N #6
Have you pulled them while running? My neighbor's Jubilee was only running on two. He swore up and down he had the firing order right. I started pulling wires while it was running. Swapped the two offenders and it runs great.
/ Busted 8N #7
Just for giggles are you sure the rotor in the distributor turns in the direction you have for the firing order turning the other way would give you 2 plugs not correct.
/ Busted 8N
I actually did replace the plugs and gapped them to spec. I replaced so many things that I forgot to mention new plugs above. Thanks for the response.
/ Busted 8N
That's something I haven't tried. It just barely runs right now and I'm not sure it'd run long enough to try that. I'll give it a try though. Thanks
/ Busted 8N
Good call, however, the rotor turns counterclockwise and I'm counting CCW when checking the correct spark plug wire routing.
My current thinking is a possible vacuum leak in the intake manifold.
/ Busted 8N #11
The quick and dirty method of checking for vaccum leak is spraying starting fluid through a straw around manifold to see if engine change's. Set a fire extinguisher where it's handy before you begin. Regarding timeing,are you aware that TDC come's up TWICE,(once to compress and fire then again to exhust) on each combustion cycle? You might try pulling distrubitor then restabbing 180 degrees.
/ Busted 8N #12
motownbrown has a point - will not hurt anything just switching the 2 offenders if you know what 2 they are just to see .
/ Busted 8N #13
just read jaxs's post could be distributor off as he says - we had that exact thing on a rebuilt engine when we got it back after rebuilt
/ Busted 8N
Good point, except I used a "plug whistle" which whistles on the compression stroke to confirm that it is on the correct up stroke of the piston.
Cool Plug whistle: Innovative Products of America 7894 Flexible Compression Whistle Amazon.com: Innovative Products of America 7894 Flexible Compression Whistle: Automotive
/ Busted 8N
I will try that when I get to the tractor next. Thanks
/ Busted 8N
I have new manifold and head gaskets coming in the mail. The whole manifold is only held on with four nuts on studs. I'll replace the gasket and check for cracks in the manifold when I have it off. Hopefully no need for a fire extinguisher haha.
/ Busted 8N #17
when you find the problem please post it - thanks in advance
/ Busted 8N
Will do, I figure once I find out what the problem is and fix it I will have replaced everything that can be replaced on a flat head Ford and I should be good for a long while, and learned a lot about my tractor in the process, knock on wood.
/ Busted 8N #19
Have you replaced the ignition switch? After time the switch can start acting intermittently. It will test "good" with a static continuity test but then during operation cut out intermittently. You can bypass the switch altogether by disconnecting from the leads and directly connecting the wires together and then starting the tractor to see if things improve.
/ Busted 8N #20
I HAD SOME PROBLEMS WITH ENGINE PERFORMANCE ON A 9N.AFTER REBUILDING AND STILL THE SAME. I DISCOVERED IT HAD A AFTER MARKET COIL AND THE RESISTER TO THE COIL WAS JUMPED. REPLACED WITH FORD PARTS AND IT RAN WELL. DOES THE COIL MATCH THE 6 OR 12 VOLT BATTERY? NEG. OR POSITIVE GROUND?
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
2012 KENWORTH T800 (A67714)
2012 KENWORTH T800...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
HEAVYEQUIPMENT HOSES (A68842)
HEAVYEQUIPMENT...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
