6210 Fuel Pump
/ 6210 Fuel Pump #1
Believer
I'm trying to resolve a fuel problem on my 6210. I have no fuel coming out of the tank. There is a 3 wire connection going into tank through a bulkhead fitting. Across 2 wires I have 6 volts so I'm assuming this is the fuel level sensor. So I'm guessing I should see 12 volts on the other wire that would power the pump, but I don't. This is hoping someone can confirm for me before I go further.
I did replace a 30 amp fuse that powers the pump. Another odd thing that happened whit this problem is that now with switch off, the fuel gauge needle is almost pegged out clockwise, ie 360 degrees from where it should be. Then when I turn ignition to run, thee needLe moves counter clockwise about 90 degrees which is still much over the full position.
/ 6210 Fuel Pump #2
There are three wires.
Orange is for the fuel gauge sender.
Red powers the fuel pump.
Black is ground.
Fuel gauge sender and fuel pump share the same ground
I assume the fuse you replaced is F101 30A
/ 6210 Fuel Pump
Thanks zebra. I should measure 12 volts black to red when I turn ignition switch to run, correct?
2011 MERTZ BLENDER TRAILER (A67714)
2011 MERTZ BLENDER...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
2015 Peterbilt 320 Roll-Off Truck (A66736)
2015 Peterbilt 320...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2016 JOHN DEERE 331G SKID STEER (A65056)
2016 JOHN DEERE...
