6210 Fuel Pump
/ 6210 Fuel Pump #1
Believer
I'm trying to resolve a fuel problem on my 6210. I have no fuel coming out of the tank. There is a 3 wire connection going into tank through a bulkhead fitting. Across 2 wires I have 6 volts so I'm assuming this is the fuel level sensor. So I'm guessing I should see 12 volts on the other wire that would power the pump, but I don't. This is hoping someone can confirm for me before I go further.
I did replace a 30 amp fuse that powers the pump. Another odd thing that happened whit this problem is that now with switch off, the fuel gauge needle is almost pegged out clockwise, ie 360 degrees from where it should be. Then when I turn ignition to run, thee needLe moves counter clockwise about 90 degrees which is still much over the full position.
/ 6210 Fuel Pump #2
There are three wires.
Orange is for the fuel gauge sender.
Red powers the fuel pump.
Black is ground.
Fuel gauge sender and fuel pump share the same ground
I assume the fuse you replaced is F101 30A
/ 6210 Fuel Pump
Thanks zebra. I should measure 12 volts black to red when I turn ignition switch to run, correct?
2012 SHOPMADE T/A GOOSENECK TRAILER (A67714)
2012 SHOPMADE T/A...
2024 KUBOTA SVL97-2 SKID STEER (A65056)
2024 KUBOTA...
AGT 2 Post Car Lift (A64912)
AGT 2 Post Car...
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
