5xxxE tractors
/ 5xxxE tractors
I found a 6330 a few hours away that I am going to look at. 105HP, bigger frame, 10k lbs and pre emission. They also have a 6115D that I might pick between. It is 118 HP and doesn’t take DEF but has a DPF.
/ 5xxxE tractors #12
Light or not, a 5090 can be bogged down to the frame. IMHO there is no comparison between the 5075 frame and the 5090/5100 frame, which is why I went with the 5090. 5090 and the 5100 are the exact same tractor with fuel delivery differences. You are doing the right thing by looking at the 6 series if weight is what you need. Mine does a good job getting power to the ground but my tires are filled and it usually takes 4wd if it is wet.
/ 5xxxE tractors #13
Those 6k series E & D are not in the same League as the 6330 & M Series made in Mannheim.
Check All of the Specs First.
The 5085E & Bigger 5k series are Great with fluid AND weighted BUT the weight Kills HP on Hills pretty bad under 115hp.
The 3cyl E has a dry clutch which MAY be ok for a Homeowner that doesn’t see ANY abuse.
Lots of Variables 😁
/ 5xxxE tractors #14
@bdog did you pull the trigger on that 6330 🚜 ?
/ 5xxxE tractors #15
Did you look at these? I would lean towards the 6330, but know little about the 6115D
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
2019 Ford Expedition MAX 4x4 SUV (A59231)
2019 Ford...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A59230)
Pallet of...
2019 F150 (A61306)
2019 F150 (A61306)
