58 MPG by 2032
/ 58 MPG by 2032 #301
/ 58 MPG by 2032 #303
Did the State of Texas just kill electric vehicle sales in Texas?
Average Road Taxes yearly for a ICE vehicle is $88 per year.
That’s equal to about 440 gallons of gas. At $0.20 per gallon, the standard car owner in Texas is paying just $88 per year in gas taxes—far less than the hundreds more EV drivers will now be throwing into the pot.
Texas just upped that to $200.00 annually for Electric Vehicles.
/ 58 MPG by 2032 #304
Electric is 14 cents a kw. Not what is cost you but the cost of
producing the power you use from the electric plant
willy
Electrical Power Costs is a two factor cost system.
Manufacturing Costs:
1. The cost it cost a manufacture to manufacture a kilowatt of electrical current. This is proprietary information not provided to consumers or the public.
Consumer Costs:
2. The cost it cost us as consumers for each KWH of electricity we use. This cost is arrived at by:
a. Check Your Bill: Review your electricity bill to find the total kWh consumed during the billing period.
b. Divide and Calculate: Divide the total cost by the total kWh consumed to find the cost per kWh.
/ 58 MPG by 2032 #305
Actually 3 factor here when the 7.5% Oakland Utility User Tax is added...
We have more factors too... like the Power Charge Inference Adjustment and Franchise Fee Surcharge.
Just opened the latest bill with average daily use of 10.29 kWh... it's worse than I thought!!!
53.24 cents per kWh Peak x 63
44.896 cents Off Peak x 234
The fees and taxes are in ADDITION to the above rate!!!
/ 58 MPG by 2032 #306
At 50 cents a kWh it is easy to see why the influx if solar.
Every week someone in the neighborhood is getting or adding and most have plug in vehicles.
/ 58 MPG by 2032 #307
Probably also have a fourth.
Hospitals need uninterrupted electrical power 24/7. So that means Generators capable of providing electrical service for critical care equipment and data flow must also be readily available 24/7.
The manager of a Data Center told me one time one of the most expensive things is when he has to generate electrical power to keep the Data Center operational when he loses his primary electrical service. He got to talking about maintaining Electrical Sine Wave parity when his primary electrical service drops out is a huge headache.
He is the one that also told me Federal Regulation are very stringent for Hospitals and Data Centers when it comes to Generators and fuel types.
/ 58 MPG by 2032 #308
That chart must be a couple years old as it deffently is not
up to date! The rates here in Texas is $0.115 to $017.5
willy
/ 58 MPG by 2032 #309
32 states charge an annual fee for electric vehicles, to offset the loss of gas taxes. Texas joins a number of other states that charge $200 to $211, Washington charges up to $225.
Electric vehicles can be considerably heavier than conventional vehicles.
/ 58 MPG by 2032 #310
The chart of utility rates is pretty close for me in Illinois but by the time you add in all the taxes and other fees it’s probably a couple of Pennie’s more.
/ 58 MPG by 2032 #311
The amount due on my bill includes taxes and other fees if any. This is the amount I pay. i have never paid a separate bill for taxes and fees on a utility bill.
Be glad you don’t live in NC. In 2016 we had a political change. One of the things started when the (R’s) moved in was a tax on Labor.
The average auto tech in NC is making 20-30 dollars an hour. Dealers are charging 85-200. Can you see where the greed is?
/ 58 MPG by 2032 #312
Ours all shows up on the same bill. It’s just the electricity is about 12 cents a kilowatt but by the time you figure the rest in it adds up to more.
/ 58 MPG by 2032 #313
And now excellent Hospital generators are targets for retirement if they happen to not be tier 4 final… BAAQMD
/ 58 MPG by 2032 #314
Our power spiked from 11c/kwh to 17c/kwh, I didn't even realize it. I installed new equipment to cut power, and factored the cost of the equipment would pay for itself in about 15 months. The bill didn't go down the next month by any measurable amount so I went to verify that the usage recorded was lower. I have my own instruments for monitoring consumption as well. The reading was ~2500kwh, vs the forecasted 3500kwh on the old equipment. However that massive increase in costs just killed any savings I would have seen.
I will be pushing my solar array install up to as soon as possible to try and further offset the increased costs. It's really not a selling point for EV's when it's going to cost me more to run them. Once I have a big enough array in place I'll be ordering batteries and disconnecting entirely.
/ 58 MPG by 2032 #315
More are doing this…
At the rate of increase there might come a time when we look back and say remember when it was 50 cents a kWh?
Many have made substantial reductions with LED lighting and more efficient appliances.
The big counter is A/C is becoming very much the norm on new and retrofit installs.
A person with a 2500 square feet home averaging 12 kWh a day in the summer gets quite a shock when the first bill comes after running the new central A/C plus 4 to 9 is peak tier pricing…
The newest proposal is equity billing so those with more pay at a higher rate so those with less will pay a lower rate.
Is it me or does anyone else think change is on overdrive from all sides?
/ 58 MPG by 2032 #316
Well, at 17c/kwh, the payback will be even faster! Imagine what you'd be paying if you hadn't done the upgrades.
Yes, but then I wonder if it's just a matter of perspective. Things always seem static when you're a kid, "things have been this way forever," just not realizing the change your parents and grandparents have seen in their lifetimes. Then you get old, look back, and say "what the hell happened?"
We're air-conditioning about 7800 of our 8100 sq.ft., plus running a swimming pool at 87 -89 F on a heat pump. Our all-in cost on electric has been hanging around 19c/kwh for a very long time, thanks to both cheap nat.gas in PA and our several nuke plants. If our electric went to 50c/kWh, I'd be paying about $1300/month in electric, based on current usage.
/ 58 MPG by 2032 #317
Natural Gas was always touted as clean but no more with outright new construction bans and utilities say this will increase costs…
/ 58 MPG by 2032 #318
It's still pretty clean. A ventless gas stove in your house may not be as clean as an electric appliance powered by a gas-fired electrical plant, but it was really the health impact on children growing up in houses with ventless gas appliances, which put the final nail in that coffin.
I've posted a graph showing our (USA) electric production by source at least three times in this thread, and you can see the way gas has grown over the last few years, in its climb to completely replace coal. That's a good thing, I think. Maybe not as good as nukes, and nowhere near as good as renewables, but still better than the coal we'd been using 40 years ago.
/ 58 MPG by 2032 #319
That's what I told my wife, but she just sees the bottom line and how I promised it would save money, and hasn't.
/ 58 MPG by 2032 #320
But it has! If you could flip some switches to simulate the old setup, she'd see that right-quick.
