55gal snow roller/ compactor
   / 55gal snow roller/ compactor #1
NS Gearhead
Nova Scotia, Canada
Deere X350
I'll get some pics up later today, but first one question; how much weight do I need to effectively compact snow? I'm planning on putting 20gal of washer fluid in it (1/3 full, up to the axle where I would leak out) about 170lbs. I could add a cinder block tray...three would add 120lbs, so 290lbs...but I'd rather not if it's not needed. What do you think?
It is a 55gal plastic barrel. Approx 3' long, 2' diam.
   / 55gal snow roller/ compactor #3
I think it would compact the snow IF you went over it a few times. Why compact it? Why not plow/blow it?
   / 55gal snow roller/ compactor #4
Depends on how much snow you are trying to compact and how dry/wet your snow is. Are you trying to compact it hard enough to walk on, snow shoe, drive?
An easier way might be to add weights to the frame around the roller then you can add/remove them as you need. For rolling ski trails we use just the roller and the tracks of the snow machine to pack it down. Some places add 25-150lbs of weight to a 6' wide roller. Let it sit over night and it'll be somewhat firm. It helps to pack it in layers, if you pack several 6" snow falls it'll be firmer than trying to pack one 24" layer.
Going over it a few times will keep packing it down but unless you have moist snow and/or a few freeze/thaw cycles it'll never be like concrete.
   / 55gal snow roller/ compactor #6
I'm going to guess the plastic barrel will crack, They don't like cold.
It's a decent hill, but when we get a foot of snow, nobody's getting anywhere until it gets packed down. Sure, you could spend the afternoon scooting yourself 6" at a time and wade through a couple feet of snow on your way back up, but that gets old fast... I'm just trying to do something nice for the neighborhood kids. I'm 7 hours in & $90. Just needs another coat of paint and final assembly. I also plow a walking path back up the hill and brought over a heavy pallet for dragging.
   / 55gal snow roller/ compactor #10
If its a decent hill how are you going to drag 290 lbs up the hill and If you do what's going to stop it from dragging you down the hill.
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A55788)
2009 Peterbilt 384...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
