55gal snow roller/ compactor
/ 55gal snow roller/ compactor #21
I'm interested in how this turns out for you. I plow 200 yards down over our hill for sledding. I've done it many different ways.
Sometimes I have plowed it with the plow raised up a bit.
Have used the back blade with the blade turned around backwards.
I end up building a snow tubing run with banked sides and corners so it is usually pretty difficult to maintain it after another decent snowfall.
It would be nice to go back down the run and pack it down rather than plowing.
I have a design in my head for a sled that I could pull to maintain 4" base and move the excess snow to the banked sides. Just never made it to the top of the list...
/ 55gal snow roller/ compactor #22
I,m surprised that your tracked wheeler wouldn,t be enough to compact the snow, with it,s own tracks. Or how about making a simple drag like they use for packing snowmobile trails ? Even an old car hood with some weight would work.
/ 55gal snow roller/ compactor #23
I groom a fair amount of snowmobile trails so here are my 2 cents. To your point, I can just run the Tucker with no drag and pack with its tracks, it does a good job but I have to go over everything twice to cover the trail.
The drag is for making the trails smooth. We like to pack them by rolling them first, otherwise the drag's pan blows the snow off the trail!
If the picture post, you can see the roller tires behind the red drag- I can take a better pic if anyone is interested.
Yes the tracks do compact the snow somewhat... but they are made to float on top, so I thought this may work better. Tried it this morning...with so so results. First, the snow's extremely powdery. I can stomp in one spot and it just keeps shifting around like sand. Second, the barrel is too slippery. Tried flattening ridges left by towing the pallet, and it would just slide sideways. I'm wondering if there's a size of corrugated culvert that would press fit over it. This would streghthen it and keep it going straight. If not I have an old truck bed liner I may be able to wrap around it. One thing I'm kicking myself over; when I welded the axle to the plates on the barrel, I only tacked them in four spots. If I would have welded all around it would have made a water tight seal and air could have put more in it... maybe next season.
...also, if it gets tilted sideways the washer fluid leaks out. :( I did go back and tried putting a bead of silicone, but it's really cold outside...not sure if it will work. Oh well, these should be pretty easy improvements to make. Hard to predict everything.
/ 55gal snow roller/ compactor #26
I think what you have will end up working. Super low moisture snow is impossible to work with anything. That is what I was in in my third pic above in the 97 Tucker. You can see it gets pushed out of the way too easily, 14"=2" packed!
/ 55gal snow roller/ compactor #27
Why don't you tow a few kids around on a toboggan for an hour?
/ 55gal snow roller/ compactor #28
That's right, once your snow turns to sugar (or around here we call it "depth hoar" because its usually buried at the bottom of our snowpack) it is very difficult to work with. You'll have an easier situation next winter if you can pack the snow starting early in the season.
/ 55gal snow roller/ compactor #29
Last year when we had 3 weeks of 10F (or below) in which we got 2-3 feet of snow (that settled into ~2' of snow), I used the snowblower on the 3 point to pack down a sledding hill.
I backed down the hill blowing off about a foot of snow, then I drove back up letting the blower float on top of the snow.
I ended up with 4-6" of nice hard packed snow that was perfect to sled on and the blow packing down the snow filled in my tire tracks nicely.
Aaron Z
Well a quick internet search shows that the OD of my barrel s 23.3". If 24" corrugated poly culvert is measured in ID, it may be feasible to marry the two. Finding a 3' length for cheap may be difficult though...
Better late then never;
1.5" 3/16" wall square tubing... so far; $0 spent
Coupler was on sale for $8
Nuts, bolts and washers were $8 This was by far the messiest thing I've ever done in my life. I put the plate down, pushed the bolts through... but then I had to carefully start the nuts on the back through that 2" hole. Then fish the wrench on to the nut... but once I tightened it down the PL Premium squished out all over my hand and wrench. It got everywhere.
My first mistake was not completely welding the axle to the plates. I only welded 4 spots. Now that it's together I'd have to cut it apart to finish weld... and I may do that once it's home from the hill in the spring.
The axle is capped and held in place with those capped 2" pipe ends... then obviously drilled and tapped with a grease fitting. When I take it apart to finish weld the axle I may step down the axle to 3/4" pipe and upgrade to pillow block bearings. They're on sale at PA right now for $7 each.
Even packed some of the snow empty!
20 gals of -35deg washer fluid. Once I seal the axle it'll be able to be filled.
Didn't make much difference, but then again this was already packed down. Also, I noticed that it wants to slide side to side too easy. I'm trying to locate a 3' length of 24" culvert to slide over to give it some side to side grip. That'll be done before next winter.
/ 55gal snow roller/ compactor #32
Your ingenuity never ceases to amaze me!! :thumbsup:
/ 55gal snow roller/ compactor #33
cool project,
i wonder if a large logging rope could make the corrugation you want.
start from the outside and wind the rope towards the middle, a few inches apart
each wrap, and then do the same from the other end. i would imagine some PL would hold the rope in a few places?
cool project,
I'm not too fond of the rope idea, but this made me think perhaps gluing strips of puck board might get the results I'm after!
/ 55gal snow roller/ compactor #36
How about towing a couple old tires behind you?
How about using 1/2" stone as ballast instead of windshield washer fluid? You could throw a couple gallons of washer fluid in to keep it from freezing if it got wet.
Using the frame you already made could you get 4 tires and wheels off an old car and mount to an axle to let them roll as you drive like the barrel you have?
I love fiddling around making trails in the Winter, when we have snow (not this year) I use my old Case crawler and back drag the snow.
Years ago I remember a state of the art snow groomer that used a compactor plate built into the rear pan and that trail would hold up very well compared to other clubs I rode in the same area.
Yeah, I'll just scrap what I've got and do that. :rolleyes:
I built it this way because that's what I had kicking around. I've also identified a couple of improvements I can make, for little to no money.
John Deere Tractor Fenders (A65640)
John Deere Tractor...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
John Deere 185 Hydro Riding Tractor Mower (A66285)
John Deere 185...
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
2022 EZ-GO ELITE...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
