5525 Break In???
/ 5525 Break In??? #1
flawton
New poster, hello all.
Last week I purchased and took delivery of a new 5525. After allowing it to warmup I began punching some gate post holes with my 12" auger. While moving locations I would increase the throttle and anytime I go above 1500 RPMS I get billowing plumes of blueish white smoke and the engine misses a little. Drop the throttle below 1500 it stops, back above 1500 it smokes. Oil is fine, coolant is fine, drained a little fuel and no water present. Engine temp is at operating temperature. Is this normal on an engine with 3.5 hours?
Dealer is closed until Wed, just thought I'd ask yall.
Thanks
/ 5525 Break In??? #2
Thanks
Flawton,
My 6520 didn't smoke at all. I never took it above 2000 rpm for the first 100 hours. Now I have 196 hours and run it wide open while using my backhoe.Do you smell cooking paint? The paint will heat and give off a smell for awhile.
hugs, Brandi
/ 5525 Break In??? #3
flawton,
Give your dealer a call, you are having a problem with your OSB sensor, or the injection timing is off. It should be a easy problem to correct, no big deal. Good luck with it!
/ 5525 Break In??? #4
bindian said:
Flawton,
hugs, Brandi
Hey Brandi,
Where did you set your rpm while bush hogging for the first 100 hours? My 4530 has only 20 hours on it, and the rpm setting for the pto is at 2100. Should I lower it for the first 100 hours?
Mud
P.S. Flawton, sorry about hijacking your thread
/ 5525 Break In??? #5
MUDONTHETIRES said:
Hey Brandi,
Mud
Mud,
I keep right below 2000 rpm while mowing. Which wasn't the best cut. I have since learned that you run it hard to break it in after the first hand full of hours. Cummins says that also for the Dodge truck.
Merry Christmas hugs, Brandi
/ 5525 Break In???
Thanks for the replies, called the dealer this morning and he is closed till the 2nd.
Sure is tough to have a big new toy and not be able top play with it.
FL
/ 5525 Break In??? #7
FL
Flawton,
Ouch! That hurts. I had an hour to kill this morning, so I went by my dealer to talk shop with my friend and salesman. He wasn't there, but they were open for business. He is stuck up in Nebraska with weather. He had to stop on the way up last Saturday in OK City for weather.
/ 5525 Break In??? #8
FL
Hey FL,
If you haven't already, log on the the 24/7 Owners Care page on Mahindra's website and type in your problem. They most likely won't know the problem but telling them where you purchased your tractor and the problem your having may get the ball rolling quicker. I had one issue with my new Mahindra a few weeks ago and logged on to their website. They assured me that they would contact my dealer. The next day, I received a call from my dealer. If they do contact your dealer, hopefully you'll be one of the first customers they call Jan. 2nd. It's worth a try!
Mud
/ 5525 Break In??? #9
FL
let it really warm up, after the temp gage shows its warmed up the sputtering will stop, when the weather warms up you wont have to let the tractor warm up. when its cold out run it up to 1500 rpm and let it sit till it warms up or go ahead and start working, it will warm up.
/ 5525 Break In??? #10
Is is smoking and sputtering right when you crank it up or is it doing after it's been running 20 minutes or so?
If it's doing it right when you crank it up it is more than likely a bad KSB timer. If it does it after it's been running at least 20 minutes the timing needs adjusting.
/ 5525 Break In???
Dealer said the injector timing is retarded and the engine is starving for fuel. Says he has seen a couple come from the Calhoun facility like this (I'm in Macon,GA). Going to pick it up today and I will post the results after a long weekend of work with it.
Once again, thanks for all of the replies.
FL
/ 5525 Break In??? #12
At the risk of displaying my ignorance, Red, how about using common terms,
i.e. OSB, KSB. I'm pretty savy with terms used on gasoline engines as I have worked on them a lot in the past, but never having to do mechanical repairs on my diesels, kow (knock on wood), Im not familiar with them. Looking at the diagrams that refer to such tems, I can figure out their functions. Having a 5525, just thinking ahead if I should encounter problems as such in the future.
By the way, weather recently was down to 29 F, my 5525 fired up with turn of the key.
/ 5525 Break In???
Dealer advanced the injector timing about 1/16 of an inch and big red is running stong, no smoke at all.
Put it to the test this weekend and couldn't be happier.
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
2022 EZ-GO ELITE...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A65563)
2006 GMC W3500...
2005 MACK CV713 DUMP TRUCK (A65643)
2005 MACK CV713...
2012 Chevrolet Colorado Crew Cab Pickup Truck (A64194)
2012 Chevrolet...
New/Unused Fuel Delivery Tank with Pump (A65583)
New/Unused Fuel...
