Oil & Fuel 5220 Fuel Line Problems
/ 5220 Fuel Line Problems #1
vobpc
Glenville, PA
JD 5220
The tractor wouldn't start about a month ago.....first time in over 1200 hours it didn't start on three turns of the starter. JD Tech came to the house and found a pinhole leak in the fuel supply line cut out the bad piece, replace it and also put in a backflow preventer. The machine went back to running good for a couple of weeks where it was used daily.
Today, after stiing unstarted for about 8 days, the same thing happened again......a brief rumble of the engine when the starter turned and the just cranking. I checked the fuel solenoid, the cutoff valves, tried bleeding at the fuel filter but no luck. Looked for another pinhole leak but didn't find anything. I'm assuming I got a new fuel filter when the tech was here the first time.
Before I call JD again, I thought I'd ask if anyone had a similar problem that was caused by something other than a leak in the supply line.
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2003 Freightliner MC 331 2,800 Gallon Fuel Truck (A68183)
2003 Freightliner...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
Unused 2023 Norden SQ90 Hydraulic Bale Squeeze Tractor Attachment (A66734)
Unused 2023 Norden...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2013 Ford F-150...
