Oil & Fuel 5220 Fuel Line Problems
/ 5220 Fuel Line Problems #1
vobpc
Glenville, PA
JD 5220
The tractor wouldn't start about a month ago.....first time in over 1200 hours it didn't start on three turns of the starter. JD Tech came to the house and found a pinhole leak in the fuel supply line cut out the bad piece, replace it and also put in a backflow preventer. The machine went back to running good for a couple of weeks where it was used daily.
Today, after stiing unstarted for about 8 days, the same thing happened again......a brief rumble of the engine when the starter turned and the just cranking. I checked the fuel solenoid, the cutoff valves, tried bleeding at the fuel filter but no luck. Looked for another pinhole leak but didn't find anything. I'm assuming I got a new fuel filter when the tech was here the first time.
Before I call JD again, I thought I'd ask if anyone had a similar problem that was caused by something other than a leak in the supply line.
PORTA POTTY (A67714)
2017 John Deere 331G Compact Track Loader Skid Steer (A66734)
2017 John Deere...
JOHN DEERE 544K (A67714)
JOHN DEERE 544K...
2012 SPARTAN GLADIATOR FIRE TRUCK (A66091)
2012 SPARTAN...
2019 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65056)
2019 CATERPILLAR...
2010 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2010 Ford F-150...
