5205 vs 5225
/ 5205 vs 5225 #1
zwk2433
AL
Y'all:
What do you think about these two tractors?
the 5205 is the big boy of a smaller series and the 5225 seems to be the small one of a bigger series.
They both have roughly the same horsepower.
I need it to spray with booms and go through the right of way and mow some rough brush in AL.
Thanks,
Zack
/ 5205 vs 5225 #2
I went with the 5205 4wd with 522 fel & canopy and I am now regretting it..Wish I would have looked at another series or even a different manufacturer because the 5205 does not have enough low forward gears and most important of all, they are not syncromesh which means you have to come to a complete stop to move up or down in the gears (can not shift on the go, only forward to reverse in low range a)..
/ 5205 vs 5225
Thanks a lot.
That is great to know. I can spend the extra money for the 5225 and feel good about it now.
Thanks,
Zack
/ 5205 vs 5225 #4
I think TSS Top Shaft Syncro is an option on most of the 5000 series tractors. I have a 5200 w/ TSS. Where in Alabama are you?
/ 5205 vs 5225
I live around Birmingham. I think that you can shift on the fly (using the clutch) on the 5225, at least that is what the salesperson told me.
I have come to find out that you can't get as many remotes as I need on the 5205. Even if you did rig them on there, now you've got something that's rigged and the extra cost gets you pretty close to the 5225.
I might just be trying to justify buying more tractor.
Zack
/ 5205 vs 5225 #7
I can shift with my 5525. You can't change the range while moving, but changing gears (with the clutch of course) works fine.
D.
KBH Tender (A63688)
KBH Tender (A63688)
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
CASE 590 SUPER M SERIES 2 BACKHOE (A65053)
CASE 590 SUPER M...
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
