5205 vs 5225
/ 5205 vs 5225 #1
zwk2433
AL
Y'all:
What do you think about these two tractors?
the 5205 is the big boy of a smaller series and the 5225 seems to be the small one of a bigger series.
They both have roughly the same horsepower.
I need it to spray with booms and go through the right of way and mow some rough brush in AL.
Thanks,
Zack
/ 5205 vs 5225 #2
I went with the 5205 4wd with 522 fel & canopy and I am now regretting it..Wish I would have looked at another series or even a different manufacturer because the 5205 does not have enough low forward gears and most important of all, they are not syncromesh which means you have to come to a complete stop to move up or down in the gears (can not shift on the go, only forward to reverse in low range a)..
/ 5205 vs 5225
Thanks a lot.
That is great to know. I can spend the extra money for the 5225 and feel good about it now.
Thanks,
Zack
/ 5205 vs 5225 #4
I think TSS Top Shaft Syncro is an option on most of the 5000 series tractors. I have a 5200 w/ TSS. Where in Alabama are you?
/ 5205 vs 5225
I live around Birmingham. I think that you can shift on the fly (using the clutch) on the 5225, at least that is what the salesperson told me.
I have come to find out that you can't get as many remotes as I need on the 5205. Even if you did rig them on there, now you've got something that's rigged and the extra cost gets you pretty close to the 5225.
I might just be trying to justify buying more tractor.
Zack
/ 5205 vs 5225 #7
I can shift with my 5525. You can't change the range while moving, but changing gears (with the clutch of course) works fine.
D.
Pallet Racking (A65640)
Pallet Racking...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Iranch High-End Tricycle (A64119)
Iranch High-End...
IRanch High-End Tricycle (A64119)
IRanch High-End...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
