5093e Transmission problem
/ 5093e Transmission problem #21
I just purchased a 2014 5065e and have about 25 hrs on tractor and noticed gear whine in B3 and B4. These are the gears i seem to use 99 percent of the time, but have whine in other gears depending on rpm/ load. I run a 7ft heavy duty brush cutter, cutting hay 3 to 4 foot high and heavy. Running at 2300 rpms in b3 after hydrualics have come to full temps seems the gear whine is really bad, and gets worse when climbing hills/ putting load on gear drive train. Was going to let tell dealer and see what they have to say. Good luck with your repairs.
Could be the same issue. Mine had the noise since new but was only noticeable under high load at first. Eventually it got so bad I couldn't mow in b4 it was so loud and I could feel play in the driveline when applying /releasing accelerator. Took 1000 hours to get to that point though.
Best thing to do is get the dealer to check it out, at least then it will be on record in case something happens shortly after the warranty is out.
2008 Sterling L7500 Series T/A Vactor 2115-J6 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
Unused Hustler DG LM200 SS 79in Hydraulic Dual Cylinder Grapple Loader Tractor Attachment (A66734)
Unused Hustler DG...
8ft Fork Extensions (A66734)
8ft Fork...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
Club Car Emergency Cart (A64557)
Club Car Emergency...
