5093e Transmission problem
/ 5093e Transmission problem #21
I just purchased a 2014 5065e and have about 25 hrs on tractor and noticed gear whine in B3 and B4. These are the gears i seem to use 99 percent of the time, but have whine in other gears depending on rpm/ load. I run a 7ft heavy duty brush cutter, cutting hay 3 to 4 foot high and heavy. Running at 2300 rpms in b3 after hydrualics have come to full temps seems the gear whine is really bad, and gets worse when climbing hills/ putting load on gear drive train. Was going to let tell dealer and see what they have to say. Good luck with your repairs.
Could be the same issue. Mine had the noise since new but was only noticeable under high load at first. Eventually it got so bad I couldn't mow in b4 it was so loud and I could feel play in the driveline when applying /releasing accelerator. Took 1000 hours to get to that point though.
Best thing to do is get the dealer to check it out, at least then it will be on record in case something happens shortly after the warranty is out.
2022 PETERBILT 579 6X4 T/A CAB AND CHASSIS (A69167)
2022 PETERBILT 579...
2025 Swict 78in Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
2012 Ford F-250 Crew Cab Pickup Truck (A66736)
2012 Ford F-250...
AUCTION STARTS HERE @ 9AM (A65056)
AUCTION STARTS...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
2016 Toyota Camry Sedan (A66738)
2016 Toyota Camry...
