504 loader
/ 504 loader #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
Hi all just woundering if a 504 loader on a B3200 can lift a 1000 lb pallet off the ground dealer stated no problem.I would like to no if anyone has done this before i spend money on forks. Thinking about firewood stacking thanks in advance ed
/ 504 loader #2
Mine will do it no problem mind you I bumped my pressure 300#. I have lifted 1200# with it but that was pushing it. I have lifted several 1000# round bales. You will need lots of rear ballast. I have 1000# of cast I hang on the 3pt.:thumbsup:
/ 504 loader
Thaank for the repley,one ? how did you bump up your presure thabks ed
/ 504 loader #4
Shimmed the relief in the loader valve. Best to check the pressure before you do any modifications. I went 300# over spec which is 2200# for these tractors. I would not recommend going over 2500#
/ 504 loader
How hard is to shim. The vavle or should I ask the dealer to do. It before delivier
/ 504 loader #6
If this is a new machine then I would not ask the dealer because he will HAVE TO say no. It is not difficult, just a little messy.
You can ask the dealer to check the pressure and make sure it is at spec.
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
GUIDED FISHING TRIP FOR TWO - HISTORIC SOQUE RIVER (A64277)
GUIDED FISHING...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
