504 loader
/ 504 loader #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
Hi all just woundering if a 504 loader on a B3200 can lift a 1000 lb pallet off the ground dealer stated no problem.I would like to no if anyone has done this before i spend money on forks. Thinking about firewood stacking thanks in advance ed
/ 504 loader #2
Mine will do it no problem mind you I bumped my pressure 300#. I have lifted 1200# with it but that was pushing it. I have lifted several 1000# round bales. You will need lots of rear ballast. I have 1000# of cast I hang on the 3pt.:thumbsup:
/ 504 loader
Thaank for the repley,one ? how did you bump up your presure thabks ed
/ 504 loader #4
Shimmed the relief in the loader valve. Best to check the pressure before you do any modifications. I went 300# over spec which is 2200# for these tractors. I would not recommend going over 2500#
/ 504 loader
How hard is to shim. The vavle or should I ask the dealer to do. It before delivier
/ 504 loader #6
If this is a new machine then I would not ask the dealer because he will HAVE TO say no. It is not difficult, just a little messy.
You can ask the dealer to check the pressure and make sure it is at spec.
F-250 Super Duty 4WD 6.2 (A63689)
F-250 Super Duty...
2011 INTERNATIONAL WORKSTAR 7300 CHEMICAL BOBTAIL (A65643)
2011 INTERNATIONAL...
2006 PROCO  130BBL (A65643)
2006 PROCO 130BBL...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2002 Massey Ferguson 1233 Tractor (A66285)
2002 Massey...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
