504 loader
/ 504 loader #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
Hi all just woundering if a 504 loader on a B3200 can lift a 1000 lb pallet off the ground dealer stated no problem.I would like to no if anyone has done this before i spend money on forks. Thinking about firewood stacking thanks in advance ed
/ 504 loader #2
Mine will do it no problem mind you I bumped my pressure 300#. I have lifted 1200# with it but that was pushing it. I have lifted several 1000# round bales. You will need lots of rear ballast. I have 1000# of cast I hang on the 3pt.:thumbsup:
/ 504 loader
Thaank for the repley,one ? how did you bump up your presure thabks ed
/ 504 loader #4
Shimmed the relief in the loader valve. Best to check the pressure before you do any modifications. I went 300# over spec which is 2200# for these tractors. I would not recommend going over 2500#
/ 504 loader
How hard is to shim. The vavle or should I ask the dealer to do. It before delivier
/ 504 loader #6
If this is a new machine then I would not ask the dealer because he will HAVE TO say no. It is not difficult, just a little messy.
You can ask the dealer to check the pressure and make sure it is at spec.
Pressure Washer, Air Compressor, John Deere Wagon, Boilers (A64127)
Pressure Washer...
2022 EZ-GO ELITE...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
1981 Chevrolet Corvette (A62613)
1981 Chevrolet...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
100 gal Portable Fuel Tank (A66408)
100 gal Portable...
