504 loader
/ 504 loader #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
Hi all just woundering if a 504 loader on a B3200 can lift a 1000 lb pallet off the ground dealer stated no problem.I would like to no if anyone has done this before i spend money on forks. Thinking about firewood stacking thanks in advance ed
/ 504 loader #2
Mine will do it no problem mind you I bumped my pressure 300#. I have lifted 1200# with it but that was pushing it. I have lifted several 1000# round bales. You will need lots of rear ballast. I have 1000# of cast I hang on the 3pt.:thumbsup:
/ 504 loader
Thaank for the repley,one ? how did you bump up your presure thabks ed
/ 504 loader #4
Shimmed the relief in the loader valve. Best to check the pressure before you do any modifications. I went 300# over spec which is 2200# for these tractors. I would not recommend going over 2500#
/ 504 loader
How hard is to shim. The vavle or should I ask the dealer to do. It before delivier
/ 504 loader #6
If this is a new machine then I would not ask the dealer because he will HAVE TO say no. It is not difficult, just a little messy.
You can ask the dealer to check the pressure and make sure it is at spec.
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
3Pt Rhino Forklift (A66408)
3Pt Rhino Forklift...
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
1043 (A60430)
1043 (A60430)
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
