4WD v. FWD
/ 4WD v. FWD #1
Riddler
Sonoma County, CA
New Holland TN75VA, New Holland TC45DA, New Holland TC18
While I obsess over the green, orange or blue decision, perhaps a few good folks on TBN can help me keep my sanity by clarifying the functional difference, if any, between the 4WD available on the Deere and Kubota CUTs and the FWD available on the TCxxDAs. With lots of terrain and wet winters, I need all of the traction I can get. Will I notice less traction with the NH because it is "just" front wheel drive? Or am I dense as a stone to assume that there is any functional difference between the two set-ups to begin with?
/ 4WD v. FWD #2
its not FWD but MFWD =mechanical front wheel drive , its still 4x4
/ 4WD v. FWD #3
Different nomenclature; same results. Big rear wheels, small front wheeled tractors have essentially the same four-wheel drive systems.
OrangeGuy
/ 4WD v. FWD #4
Much like the French, JD has a different name for everything but essentially its very similar or the same. Shuttle shift = Power reverser, MFWD is basically 4WD with some symantic differences not between Deere and others but between the accuracy of naming the two drives. Some will argue MFWD is more accurate except that every other person has to ask what it is. I suggest keeping it simple, 4WD works well for most of us. Lots of traction, consider some Michelin radial tires and be sure you get a tractor that has the power to turn them. /forums/images/graemlins/grin.gif
/ 4WD v. FWD #5
Technically speaking a 4wd tractor is always in 4wd. A 2wd tractor with a driven front axle added that can be turned on or off is called by many names,but is mainly known by the type of drive, mfwd(mecahanical front wheel drive) hfwa (hydraulic front wheel assist). Different companies over the years have called driven front axle set-ups by many names for marketing purposes.
/ 4WD v. FWD #6
</font><font color="blue" class="small">( I suggest keeping it simple, 4WD works well for most of us. )</font>
That is the main reason JD and Kubota use the 4wd designation instead of the FWA designation. It is so homeowners can better understand what it is without having to ask the salesman. The larger JD tractors do use the FWA designation. NH knows its buyers are educated about tractors which is why it uses FWA /forums/images/graemlins/wink.gif
DISCLAIMER: That last sentence was a joke. I do not mean to imply John Deere or Kubota compact owners are any less educated then New Holland compact owners. /forums/images/graemlins/crazy.gif
/ 4WD v. FWD #7
No disclaimer was needed....we just consider the source!!! /forums/images/graemlins/smirk.gif
/ 4WD v. FWD #8
In our area a 4wd tractor is one that had all four wheels the same size. MFWD or FWA refers to a tractor that has smaller front wheels than the back wheels.
/ 4WD v. FWD #9
That is true which is why trucks are considered 4wd even though they are not locked in all the time. What gets me is Ford/NH and JD make tractors for vegetable farms and to get clearance they put the same size tires on the front that they use on the back. They are called mudders and are usually around 70-100 hp but are they 4wd's or FWA as they are not full 4wd? /forums/images/graemlins/crazy.gif
/ 4WD v. FWD
I have a lot to learn, obviously. /forums/images/graemlins/blush.gif Thanks for setting me straight.
/ 4WD v. FWD #11
Hi,
Exactly. An " ARTICULATED " tractor in our area is 4wd, and the rest are FWA or MFD!!
Take care
Will
/ 4WD v. FWD #12
</font><font color="blue" class="small">( I have a lot to learn, obviously. )</font>
WE ALL HAVE A LOT TO LEARN /forums/images/graemlins/tongue.gif The only thing i know is when i put my b2400 in 4wd (call it what u want) the traction is xxxxxxfold compared to regular .
/ 4WD v. FWD #13
</font><font color="blue" class="small">( DISCLAIMER: That last sentence was a joke. I do not mean to imply John Deere or Kubota compact owners are any less educated then New Holland compact owners. )</font>
wondered how u was going to get out of that remark /forums/images/graemlins/grin.gif off subject a bit robert. but was does the grape crop look like with all the rain and very little sun?
/ 4WD v. FWD #14
Hello again, I have not forgot about getting together for breakfast some day either but things are very hectic this year and don't look like they will lighten up anytime soon. My little lady was due August 11th and she still is holding the little critter inside her so any time I have to be going (most likely will be when I am suppose to bale Monday or Tuesday before the rain comes in /forums/images/graemlins/frown.gif)
The grape crop is not too good this year. Low yield and low sugar because of lack of sun and too much water will make for a fun year /forums/images/graemlins/frown.gif It is like that with almost everything but apples I hear so I guess everyone will have something to be upset about this year. Maybe next year will be better.
2016 KENWORTH  W900 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH...
2021 SANY SY26U EXCAVATOR (A63276)
2021 SANY SY26U...
2008 Chaparral 204 SSI Bow Rider Boat (A62613)
2008 Chaparral 204...
Industrias America 84" Skidsteer Quick Attach Bucket (A66408)
Industrias America...
2022 EZ-GO ELITE...
Bulk Bin (A66408)
Bulk Bin (A66408)
