4707
4707, 4708, & 4709 can be factory installed with 16.9R30 18.4R30 or 16.9R34 Rear Ag Tires all three are choices in the Dealer Price Book. Also Available are the 19.5L-24 & 18.4-26 R4 Rear Industrial Tires from the Assembly Center. Each has it's own matching front tire to maintain proper front to rear gear Ratio. Just listing the rear tire options. 4710 offers 16.9R34, 16.9-30, 18.4R30 or 15.5R38 Rear Ag Tires or 19.5L-24 or 18.4-26 R4 Tires. In the Cab Versions.
I sure wish you had been my dealer! Thanks for the info.
Just to add to the discussion...
My T4.75 New Holland is shorter and lighter than the 4707...
It has 30's on the rear...
It will run 25 MPH in high gear but you have to start out in the 3rd range and 1st gear...
Speed up in each gear and change when the rpm's are maxed...
I would guess that 34's would really make it labor on the road and thus understand putting 30's on the 4707...
The 4700 series are really nice units...
The poultry version tires are to create a very low profile to fit in chicken houses. Exhaust would need to be horizontal as well
Bigpuddie, can you post links to all the parts you used? I am curious which Ram mount and magnets you used. Thank you!
Sure...here ya go:
Ram Mount Long Double Socket Arm for 1.5-Inch Ball Bases https://www.amazon.com/dp/B0055BJAV4/ref=cm_sw_r_cp_apa_i_kgcKCb9MEQEX5
RAM 1.5" Ball, Handlebar, 1.625"-1.5" https://www.amazon.com/dp/B01GQH26S4/ref=cm_sw_r_cp_apa_i_-gcKCb6ZXFZR0
RAM 6.25"" x 2"" Universal Electronics Base with 1.5"" Ball https://www.amazon.com/dp/B00CJPUPRC/ref=cm_sw_r_cp_apa_i_DhcKCbHV5T9SM
Mount Bracket Sucker Holder Magnetic Base, Roof Magnet Base Mount Holder Bracket for LED Light Bar LED Work Light Bar Offroad Lamp https://www.amazon.com/dp/B073W8V57S/ref=cm_sw_r_cp_apa_i_EicKCbYBZJCYA
I bought the 4707 with R4 tires. When I bought this tractor, it was the only one they had with an open station. I was happy to get the R4s but at the time didnt realize the difference in ground clearance. It has been a huge issue for me. I use it commercially for fencing and brush hogging. I will be in the market for taller tires this year.
And I have gigantic 34 inch R1 Trelleborg radials and want R4's, in my case, Nokian TRI 2s.
Both of us took what came with it, and regretted it
You two could swap tires, they wouldn't be the Nokians but less aggressive.
I thought about that but we're 18hrs away from each other. Im in Tulsa, Ok.
Have any of you priced front fenders?
I have them on mine. They are the swivel type. I had them worked into the deal. When the dealer found out what they cost ($1300) , he tried to weezle out if it. In the end, he kept his word. They are very heavy duty. I like them20181203_161430.jpeg
I was quoted 1700 installed. I passed. Not that much mud here and no road work at speed.
They are not that much. Take about 2 hrs to install. Parts are about $1100
my dealer said parts with shipping were much more than that. You got a very good deal.
Have you had any problems with clutches grabbing at idle? I have intermittent issues with tractor jerking forward while in idle, usually when cold. Dealer had factory rep adjust, accomplished nothing. When running machine at regular rpm, no issues, just at idle when cold. Very disconcerting to feel tractor jerk while in neutral...
I sure do like my new pin in hole stabilizers. Why they put that other variety on escapes me, only work for Cat 2 when most of our realities is a mix of both Cat 1 and 2. Maybe a supplier issue, maybe saving a few bucks where they shouldn't have. Now if I can get my tires swapped out for something better suited to me, what I really want are Nokian TRI 2's, I'd be a very happy guy.
UNUSED FUTURE D680 HYD PILE HAMMER (A65055)
UNUSED FUTURE D680...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A64556)
2012 Chevrolet...
BESTWAY AG 1600 GALLON NURSE TANK (A64278)
BESTWAY AG 1600...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A67147)
2012 FREIGHTLINER...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
