4707
my dealer said parts with shipping were much more than that. You got a very good deal.
Have you had any problems with clutches grabbing at idle? I have intermittent issues with tractor jerking forward while in idle, usually when cold. Dealer had factory rep adjust, accomplished nothing. When running machine at regular rpm, no issues, just at idle when cold. Very disconcerting to feel tractor jerk while in neutral...
I sure do like my new pin in hole stabilizers. Why they put that other variety on escapes me, only work for Cat 2 when most of our realities is a mix of both Cat 1 and 2. Maybe a supplier issue, maybe saving a few bucks where they shouldn't have. Now if I can get my tires swapped out for something better suited to me, what I really want are Nokian TRI 2's, I'd be a very happy guy.
My dealer sold them to me at cost. The stabilizers on mine are very good and stout. Most people with these tractors are using cat 2 implements, but I hear ya. 20190328_074631.jpeg
My dealer sold them to me at cost. The stabilizers on mine are very good and stout. Most people with these tractors are using cat 2 implements, but I hear ya. View attachment 597785
They were stout for sure but slow changing twist twist twist.. there was only one hole to select then you had to twist. Isn’t that the same as yours?
Did you cut the stock wiring harnesses off or buy adapters? Did you do the rear lights as well? 30 degree in the front and 60s in the rear?
Did the 30 degree front top, 60 degrees on side and rear. I did cut the factory plugs off and put Deutche connectors on. Pretty easy to do. Used the factory mounting brackets. Huge difference.
Anyone with a Visio roof have any thoughts? How is the heat in the summer? Do you think it is worth the upgrade?
My dealer has a 4707 in stock without the Visio roof and I am trying to figure out how long the wait will be if I want one with that option.
I have it. Dont notice any added heat. There is a sunshade you can pull over it. If you do alot of loader work at full height, it's great. If you dont do alot of hay stacking or high loader work, you will be fine without it.
Thanks bigpuddie. You always help me out. Appreciate it.
I definitely like it. Even though I haven’t used it a ton with loader work, it has been really nice when I did need it. I was lifting someone to do work under the eaves of my house & was happy to have it. It’s also helpful with watching for tree branches.
I haven’t run it though in summer with high heat yet..fingers crossed it works well in mid 90 degree days. You do lose a couple directional vents from up front. Instead they just blow out by the windows.
Agco I think helped my dealer find a 4707 with the option from another dealer.
How do you like the bb840, I am thinking of getting the same heavy beast. It is nice that you got a trailer that fits it between the fenders I am going to have to go deck over unfortunately because of the 85 inch width.
The Visio Roof was a deal maker for me, as I have an elevated man lift bucket to do tree pruning on my place, have a fused neck and can't bend it too well, so being able to see upwards and track the FEL is marvelous. The steel protective grill on top is overbuilt and sometimes i wish it wasn't there. Probably until my helper drops a limb on the tractor...
I have mowed roads now with the roof glass open/shade pulled back, and had to move the a/c up a notch when the
bright sun kicked in. So far it kept the cab comfortable and I had at least another speed or two left. It's also only April.
I don't find the shade all that easy to use. Spoiled by electric ones on car but don't want that here.
How about a photochromatic one that auto dims to dark when you press the Auto button. Like sunglasses.
Having a moon roof, in this case a true side to side glass roof, albeit not overly wide, is very cool to have on an under 50k tractor, plus the buddy seat. Very high value proposition on 4707 particularly now that we know you can crank up the 70hp engine to 100hp for two grand later on after the warranty is out. I think that's something to look forward to...
Be careful of the stock Trelleborg TM-600 R1 radials if you want to go over lawn. They will tear you up. Working to try to put Nokian TRI 2's on mine. The trick is getting decent money, like half..., for what I own on the tractor, $4k for the tires all around, significant part of the cost of the tractor new. Don't want hard riding R4, want hybrid.
If you farm or do hay, those stock R1's are great tires. Really be hard to get this tractor stuck with them on, plus very stable feeling while mowing roadsides near ditches on an angle.
I remain having a problem with jumpy clutches. Still grab in neutral and rocks the tractor slightly. Not an issue when
rpm increased. Another member here has had the same issue. And when I go in the Massey dealer service bay where there are really big tractors, equivalents of 7's and 8 size JD's, lot of clutch packs out for repair. Maybe that's just a normal wear item like tires. But if a trans is in neutral, it should not, IMHO, be trying to move the tractor in any direction all by itself.
Maybe with higher rpm hydraulic flow increases, but I'm just guessing. Over my pay grade.
Clearly the factory rep will be back for another one of his adjustments, this time perhaps more effectively.
Tractor was dead in the barn yesterday. No juice. Put charger on, few hours later started up fine. No loose cables, wonder if rear camera was not wired correctly and it's hot all the time. Now I turn the camera off manually before shut down.
my pin and hole lower arm stabilizers work great. Everything hooks up just fine.
FEL remains remarkably fast and powerful.
Thank you very much daugen. I am still working with my local dealer to try to get one with the visio roof. I am hoping it works out but I might end up without it. If I special order, it won’t be delivered until August. I don’t want to wait that long. I guess we will see. They can do a dealer trade but the sales manager made me think I wouldn’t get as good of a deal.
I appreciate your review and help. I am excited to get the tractor and start using it. I will keep you in the loop.
The main price difference we used to see on dealer swaps was the trucking charges to move the tractor from one dealer to the other which at a couple of dollars per mile can add up rapidly.
I love the BB840. I bought the lighter version (bb84??) first and returned it after my first use. This one has been great. I have about 140 hours mowing on it so far. I had the bb720 before and it was a great machine. Over 10 years old with thousands of hours and still runs great to this day.
Thanks, I looked at a bb72 today. Trying to find a bb840x for a good price now. It has taken a while to find a 4707 with the viso but I think I’ll have one by Thursday to pull that 1800 lb beast of a rotary.
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
Case SV300 High Flow Compact Wheel Loader Skid Steer (A66734)
Case SV300 High...
2015 KOMATSU PC490LC-11 EXCAVATOR (A65056)
2015 KOMATSU...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
2025 Mini Excavator Attachment Set (A66734)
2025 Mini...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
