4707
What tire pressure are you guys running for the front and rear tires. Unless I missed it, it’s not shown in the operation or maintenance manual. I have the ag tires. If it matters, I have the 34 inch rear tire. Coming from the dealership it was 31psi in the front and 16psi rear. Thanks, AJ
Sounds close
Hi all,
Thanks for all the information on this thread. I wished I would have found it earlier. I bought a 2022 MF 4707 last week and should have it delivered this week with a tint job on the cab. I did not order it I just looked around at many dealerships and this was on the lot near me. I did look back through the last few years at pricing and tractors have definitely followed the the trend 😆. I compared the JD 5075e, Kubota M4-071, and Mahendra 6075. Pricing on the JD was 53.5k with 520m loader, kubota was 59k, and I didn't quote mahindra after comparisons it fell off th list. I would definitely recommend price shopping with dealers as none would budge until I showed them a quote. I flew out to Arkansas for work and stopped at Brunos to test drive. They quoted 57k with cab, air ride seat and wheel weights. It had the 913x loader. The open station was 45k. I was able to use that to help get pricing down from low 60s to what we finally settled on. Thanks again for all the info in this thread and hopefully this helps someone else.
*****Edit***** I ended up paying 58.5k for the 2022 MF 4707 with radio, mechanical seat, and the non self leveling FL loader. This is in East Texas. Separately I got a 72 inch armstrong grapple and added 3rd function on the bucket. I will post pictures when it arrives.
Did you have them widen the stance once it delivered to the dealer? How do you like it ?
I did, only have 5 hours on it. Other than a hose clamp on the heater core above the cab not being on correctly, I like it so far. Clutch is very grabby, seems to not have much slip almost like on or off. The shuttle smooths that out though.
If you widen yours be sure to adjust the bump stops. If not, the left front tire on a left turn will contact the fuel tank-skid plate
Good to hear, Do a lot of mowing on hills or so? Trying to weigh out advantages of the widened stance compared to stock stance
So I’m not the only one experiencing this. Makes inching forward or backwards pretty tough. Which is a big deal.
Update: tractor was delivered back to me from the dealer a few days ago. I "think" the 3pt hitch issue was fixed, but I won't know until I hook up to trailers and start yanking them around the yard. That's hard to do with all the snow we have right now.
Also, the leak over the cab was fixed.
The hood was not fixed. You pull the small lever to raise it and it goes up a little bit then comes back down. They said they were waiting on a part. Must be the hydraulic arms.
Anyway, it's nice having the tractor back on the farm...with heat.
Curious if you’ve used the 3pt and if they got it working correctly?
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
RoadTec RP190 (A61307)
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59906)
2007 FREIGHTLINER...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
