4310 stuck in 4wd
/ 4310 stuck in 4wd #1
johnierotten
Hi, my JD 4310 is stuck in 4wd, the switch with the light in it on the right arm rest turns the light on and off but it doesnt come out of 4wd. Im guessing that there is a selonoid some where thats stuck on but could use some direction to find it or any other suggestions. Thank!
/ 4310 stuck in 4wd #2
The MFWD solenoid on the 4310 is powered when the switch is in the off position. The MFWD is held on by a spring, and disengaged hydraulically. The solenoid is on the right side, along side the PTO (and mid PTO if you have it) solenoids. Its been a while since, I worked on one of these, but I think a small hydraulic line runs under the tractor to the left side to actuate this. I would look for a disconnected connector at the solenoid or damaged wiring going to it.
/ 4310 stuck in 4wd
thanks rodger,you were right! a couple wires had gotten damaged! Thank You
2021 JOHN DEERE 304L WHEEL LOADER (A65056)
2021 JOHN DEERE...
2022 Load Lifter 5000 (A64911)
2022 Load Lifter...
John Deere 6115D (A64911)
John Deere 6115D...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A69167)
2005...
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
2014 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2014 FORD F150...
