4310 stuck in 4wd
   / 4310 stuck in 4wd #1
johnierotten
Hi, my JD 4310 is stuck in 4wd, the switch with the light in it on the right arm rest turns the light on and off but it doesnt come out of 4wd. Im guessing that there is a selonoid some where thats stuck on but could use some direction to find it or any other suggestions. Thank!
   / 4310 stuck in 4wd #2
The MFWD solenoid on the 4310 is powered when the switch is in the off position. The MFWD is held on by a spring, and disengaged hydraulically. The solenoid is on the right side, along side the PTO (and mid PTO if you have it) solenoids. Its been a while since, I worked on one of these, but I think a small hydraulic line runs under the tractor to the left side to actuate this. I would look for a disconnected connector at the solenoid or damaged wiring going to it.
   / 4310 stuck in 4wd
thanks rodger,you were right! a couple wires had gotten damaged! Thank You
HOILAND TN65 TRACTOR (A55787)
HOILAND TN65...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2014 Nissan Juke (A53424)
2014 Nissan Juke...
Killbros 450 Gravity Wagon (A50775)
Killbros 450...
UNUSED JCT 72" HYD TILLER (A54757)
UNUSED JCT 72" HYD...
Payment Instructions (A47477)
Payment...
