425 PTO GPM mad PSI?
/ 425 PTO GPM mad PSI? #1
spechols
Central, PA
Power Trac PT425
I need to make an adapter with the correct speed motor.
Does anyone know the GPM and PSI of the PT-425 PTO?
Many Thanks
Spechols
/ 425 PTO GPM mad PSI? #4
I use this calculator to determine hydraulic motor.
If you need 540rpm (to convert a farm implement) you want about a 3.4 cubic inch displacement 55cc.
Post a new thread if you need input on a specific setup.
/ 425 PTO GPM mad PSI? #5
/ 425 PTO GPM mad PSI? #6
You sure? That seems a whole lot of flow for not that much pressure. 🤣
/ 425 PTO GPM mad PSI? #7
As the specs from the factory showed about 5 minutes ago in this screen grab...
8 gallons per minute at 2500psi.
Good news is that a Terry tells me any 10 cu hydro motor should work for my needs. I am making an adapter for Gravely attachments over the winter. Got to keep coming up with something odd.
