425 PTO GPM mad PSI?
/ 425 PTO GPM mad PSI? #1
spechols
Central, PA
Power Trac PT425
I need to make an adapter with the correct speed motor.
Does anyone know the GPM and PSI of the PT-425 PTO?
Many Thanks
Spechols
/ 425 PTO GPM mad PSI? #4
I use this calculator to determine hydraulic motor.
If you need 540rpm (to convert a farm implement) you want about a 3.4 cubic inch displacement 55cc.
Post a new thread if you need input on a specific setup.
/ 425 PTO GPM mad PSI? #5
/ 425 PTO GPM mad PSI? #6
You sure? That seems a whole lot of flow for not that much pressure. 🤣
/ 425 PTO GPM mad PSI? #7
As the specs from the factory showed about 5 minutes ago in this screen grab...
8 gallons per minute at 2500psi.
2017 Ford Expedition 4WD SUV (A59231)
2017 Ford...
5' MOWER (A52706)
5' MOWER (A52706)
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
HEAVYEQUIPMENT TOOLS (A60736)
HEAVYEQUIPMENT...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
