425 PTO GPM mad PSI?
/ 425 PTO GPM mad PSI? #1
spechols
Central, PA
Power Trac PT425
I need to make an adapter with the correct speed motor.
Does anyone know the GPM and PSI of the PT-425 PTO?
Many Thanks
Spechols
/ 425 PTO GPM mad PSI? #4
I use this calculator to determine hydraulic motor.
If you need 540rpm (to convert a farm implement) you want about a 3.4 cubic inch displacement 55cc.
Post a new thread if you need input on a specific setup.
/ 425 PTO GPM mad PSI? #5
/ 425 PTO GPM mad PSI? #6
You sure? That seems a whole lot of flow for not that much pressure. 🤣
/ 425 PTO GPM mad PSI? #7
As the specs from the factory showed about 5 minutes ago in this screen grab...
8 gallons per minute at 2500psi.
2021 Deere 75G (A60462)
2021 Deere 75G...
LOT LOCATIONS (A59906)
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
Polaris Ranger (A56859)
Polaris Ranger...
2013 FORD F250 (A60460)
2013 FORD F250...
2019 BOBCAT MT55 WALK BEHIND SKID STEER (A59823)
2019 BOBCAT MT55...
