425 PTO GPM mad PSI?
/ 425 PTO GPM mad PSI? #1
spechols
Central, PA
Power Trac PT425
I need to make an adapter with the correct speed motor.
Does anyone know the GPM and PSI of the PT-425 PTO?
Many Thanks
Spechols
/ 425 PTO GPM mad PSI? #4
I use this calculator to determine hydraulic motor.
If you need 540rpm (to convert a farm implement) you want about a 3.4 cubic inch displacement 55cc.
Post a new thread if you need input on a specific setup.
/ 425 PTO GPM mad PSI? #5
/ 425 PTO GPM mad PSI? #6
You sure? That seems a whole lot of flow for not that much pressure. 🤣
/ 425 PTO GPM mad PSI? #7
As the specs from the factory showed about 5 minutes ago in this screen grab...
8 gallons per minute at 2500psi.
Good news is that a Terry tells me any 10 cu hydro motor should work for my needs. I am making an adapter for Gravely attachments over the winter. Got to keep coming up with something odd.
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2013 CHEVROLET EQUINOX LT SUV (A65054)
2013 CHEVROLET...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2011 APPCO T-BELT TRAILER (A67714)
2011 APPCO T-BELT...
UNKNOWN  TRIAXLE LOWBOY TRAILER (A67714)
UNKNOWN TRIAXLE...
