425 PTO GPM mad PSI?
/ 425 PTO GPM mad PSI? #1
spechols
Central, PA
Power Trac PT425
I need to make an adapter with the correct speed motor.
Does anyone know the GPM and PSI of the PT-425 PTO?
Many Thanks
Spechols
/ 425 PTO GPM mad PSI? #4
I use this calculator to determine hydraulic motor.
If you need 540rpm (to convert a farm implement) you want about a 3.4 cubic inch displacement 55cc.
Post a new thread if you need input on a specific setup.
/ 425 PTO GPM mad PSI? #5
/ 425 PTO GPM mad PSI? #6
You sure? That seems a whole lot of flow for not that much pressure. 🤣
/ 425 PTO GPM mad PSI? #7
As the specs from the factory showed about 5 minutes ago in this screen grab...
8 gallons per minute at 2500psi.
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Wood Native American Statue (A59231)
Wood Native...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2019 Chevrolet Express Van, VIN # 1GB0GRFP7K1370206 (A61165)
2019 Chevrolet...
2004 International 4300 ASM 4x2 AM855 Bucket Truck (A60352)
2004 International...
