425 hyd fluid ????
/ 425 hyd fluid ???? #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Hi everyone, I have 425 1996 model, I noticed today that the level of oil is low.... This is not engine oil but this is checked under the seat and has a dipstick. Is this regular HYD oil to add or a special John Deere oil? I don't have any books for this garden tractor.
Thks weeder......
/ 425 hyd fluid ???? #2
This is listed in the on-line 425 Operator's Manual:
Anti-Chatter Transmission Oil
NOTE: Tractor is filled with John Deere Low Viscosity HY-GARD® (J20D) transmission oil at the factory. DO NOT mix oils.
These tractors are equipped with a hydraulic wet disc PTO clutch. To avoid chatter, use only Low Viscosity HY-GARD® (J20D) transmission oil. DO NOT use type "F" automatic transmission fluid.
John Deere Low Viscosity HY-GARD® (J20D) transmission oil is specially formulated to minimize clutch chatter, and to provide maximum protection against mechanical wear, corrosion, and foaming. Low Viscosity HY-GARD® may be used in all temperatures.
Thanks Guys gonna get some this week at the John Deere place!
/ 425 hyd fluid ???? #5
And good idea to change the tranny filter too.
I never have, I didn't know there was a filter on it for that. All I ever changed was the oil and filter. Is it hard to do that?
Where is the drain plug on the transmission? Underneath? I looked under and saw the filter..looks like somebody had tried to take the filter off because it is bent in in a couple of places. I hope it is not froze on there?
/ 425 hyd fluid ???? #10
Deere Dude is correct on the drain plug.. to the rear, lower right-of-center. (per pic in owners manual). Will be good to have one.
Okay I found the plug and I have no manual to go by...I'm going to change the engine oil tomorrow and this weekend go for the tranny change...wish me luck and I hope the filter isn't to tight to get off???????
/ 425 hyd fluid ???? #12
Can't be too tight to get off.. in worst case drive a large screwdriver through it as a crank.. it WILL come off. :D
2018 FREIGHTLINER CASCADIA 125 T-A SLEEPER TRACTOR' (A67147)
2018 FREIGHTLINER...
2022 EZ-GO ELITE...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A65053)
2014 VOLVO A25G...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
