425 hyd fluid ????
/ 425 hyd fluid ???? #1
weeder
Tuscola Illinois
John Deere 425 lawn tractor
Hi everyone, I have 425 1996 model, I noticed today that the level of oil is low.... This is not engine oil but this is checked under the seat and has a dipstick. Is this regular HYD oil to add or a special John Deere oil? I don't have any books for this garden tractor.
Thks weeder......
/ 425 hyd fluid ???? #2
This is listed in the on-line 425 Operator's Manual:
Anti-Chatter Transmission Oil
NOTE: Tractor is filled with John Deere Low Viscosity HY-GARD® (J20D) transmission oil at the factory. DO NOT mix oils.
These tractors are equipped with a hydraulic wet disc PTO clutch. To avoid chatter, use only Low Viscosity HY-GARD® (J20D) transmission oil. DO NOT use type "F" automatic transmission fluid.
John Deere Low Viscosity HY-GARD® (J20D) transmission oil is specially formulated to minimize clutch chatter, and to provide maximum protection against mechanical wear, corrosion, and foaming. Low Viscosity HY-GARD® may be used in all temperatures.
Thanks Guys gonna get some this week at the John Deere place!
/ 425 hyd fluid ???? #5
And good idea to change the tranny filter too.
I never have, I didn't know there was a filter on it for that. All I ever changed was the oil and filter. Is it hard to do that?
Where is the drain plug on the transmission? Underneath? I looked under and saw the filter..looks like somebody had tried to take the filter off because it is bent in in a couple of places. I hope it is not froze on there?
/ 425 hyd fluid ???? #10
Deere Dude is correct on the drain plug.. to the rear, lower right-of-center. (per pic in owners manual). Will be good to have one.
Okay I found the plug and I have no manual to go by...I'm going to change the engine oil tomorrow and this weekend go for the tranny change...wish me luck and I hope the filter isn't to tight to get off???????
/ 425 hyd fluid ???? #12
Can't be too tight to get off.. in worst case drive a large screwdriver through it as a crank.. it WILL come off. :D
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
2019 Chevrolet Tahoe SUV (A64194)
2019 Chevrolet...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
