422 engine
/ 422 engine
KMA said:
I believe what Bob999 was getting at (please correct me if I'm mistaken) is that the wheel motors/pumps used on the 180 may have a more impact on "power" than the engine output. In other words, additional HP is likely not the only thing that makes the 422 and the 425 more "powerful".
I have the specs. on the 180 wheel motors from WHITE. I can't remember what the max in/lbs of torque is compared to the 422 wheel motor max in/lbs. of torque. If I look at the torque curve chart for the 18HP engine and look at the continious power rating output,which is a more realistic use rating it is considerbly less ( 14.5 HP ). So maybe by adding a few more HP I will get the full potental out of the 180 pumps, wheel motors etc. without maxing them out. If the change out is feasable after I get the remaining info. ( max hp for the180 wheel motors, pumps , etc.) then the parts costs ( governor spring, carburetor, throttle shaft ) will be $274.12 plus shipping.
Am I getting the full usable torque and power out of my wheel motors, pumps, etc. now with the 18HP --- I don't know,--the continious rated output HP is only 14.5. Thats what I have to find out.
/ 422 engine #42
My 422 engine will bog down when I'm going up steeper hills, and bog down when I've got the brush hog going and trying to go uphill. For less than $300 it's $100/hp and I may be one that's gonna go for the change.
Phil
/ 422 engine #43
Bob999 said:
If I understand correctly the specs JJ lists are for the PTO pump. That still leaves the pump for the aux circuit and the variable displacement pump that powers the wheel motors. And of course there are the wheel motors that are probably different.
PTO pump data
8 gpm @2000 psi requires 10.9 hp--18 , 22 hp engines
8 gpm @2500 psi requires 13.69 hp-25 hp engines
Can you climb those hills with out using the PTO. That should tell you some thing about your wheel motors. Those other pumps are probably using up as much hp as needed, It then depends on torque generated by the wheel motors.
If you put to much load on a hydraulic motor, it will stall out the engine or slow that engine down.
/ 422 engine #44
Hey guys,
Long time no see... I don't really have the time to read the whole 5 pages of this thread so from reading some of the posts, I just want to let the cat out of the bag on the whole EH63/64/65 hp questions.
The only differences on all three of these models are the carburetor and the governor hole setting. If you guys have any additional questions shoot them my way in this thread, I'll try to answer as soon as I can.
Regards,
Jack Gawecki
Subaru Power Products
Technical Support Dept.
800-277-6246
/ 422 engine #45
J_J said:
PTO pump data
The Power Trac website shows the PT422 having the 8gpm/2500psi PTO. :confused:
I have one... :D how can we increase the power of the EH65 without affecting reliability? :p
Thanks!
/ 422 engine
JackRobin said:
Hey guys,
Regards,
Jack Gawecki
800-277-6246
THANK YOU JACK!!- FOR COMFIRMING MY FINDINGS. I must have read the owners manual and parts manual, and engine specs. at least a dozen times and I could not find any difference other than the carb. and governor settings.
/ 422 engine #48
I thought there was an oil cooler in the 25 HP engine. So we can just change the carb and spring and up the horse power? Sounds real easy.
/ 422 engine #49
That is correct, I wasn't talking about upgrading from EH6X to EH72, the crankcase for EH72 25hp is diffrent than EH6X series.
/ 422 engine
Bob;
The 3 engines are the 18HP, 20.5HP, & the 22Hp. The 25Hp (EH72 ) is a whole different beast.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A59230)
2016 Peterbilt 320...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
