422 engine
/ 422 engine
KMA said:
I believe what Bob999 was getting at (please correct me if I'm mistaken) is that the wheel motors/pumps used on the 180 may have a more impact on "power" than the engine output. In other words, additional HP is likely not the only thing that makes the 422 and the 425 more "powerful".
I have the specs. on the 180 wheel motors from WHITE. I can't remember what the max in/lbs of torque is compared to the 422 wheel motor max in/lbs. of torque. If I look at the torque curve chart for the 18HP engine and look at the continious power rating output,which is a more realistic use rating it is considerbly less ( 14.5 HP ). So maybe by adding a few more HP I will get the full potental out of the 180 pumps, wheel motors etc. without maxing them out. If the change out is feasable after I get the remaining info. ( max hp for the180 wheel motors, pumps , etc.) then the parts costs ( governor spring, carburetor, throttle shaft ) will be $274.12 plus shipping.
Am I getting the full usable torque and power out of my wheel motors, pumps, etc. now with the 18HP --- I don't know,--the continious rated output HP is only 14.5. Thats what I have to find out.
/ 422 engine #42
My 422 engine will bog down when I'm going up steeper hills, and bog down when I've got the brush hog going and trying to go uphill. For less than $300 it's $100/hp and I may be one that's gonna go for the change.
Phil
/ 422 engine #43
Bob999 said:
If I understand correctly the specs JJ lists are for the PTO pump. That still leaves the pump for the aux circuit and the variable displacement pump that powers the wheel motors. And of course there are the wheel motors that are probably different.
PTO pump data
8 gpm @2000 psi requires 10.9 hp--18 , 22 hp engines
8 gpm @2500 psi requires 13.69 hp-25 hp engines
Can you climb those hills with out using the PTO. That should tell you some thing about your wheel motors. Those other pumps are probably using up as much hp as needed, It then depends on torque generated by the wheel motors.
If you put to much load on a hydraulic motor, it will stall out the engine or slow that engine down.
/ 422 engine #44
Hey guys,
Long time no see... I don't really have the time to read the whole 5 pages of this thread so from reading some of the posts, I just want to let the cat out of the bag on the whole EH63/64/65 hp questions.
The only differences on all three of these models are the carburetor and the governor hole setting. If you guys have any additional questions shoot them my way in this thread, I'll try to answer as soon as I can.
Regards,
Jack Gawecki
Subaru Power Products
Technical Support Dept.
800-277-6246
/ 422 engine #45
J_J said:
PTO pump data
The Power Trac website shows the PT422 having the 8gpm/2500psi PTO. :confused:
I have one... :D how can we increase the power of the EH65 without affecting reliability? :p
Thanks!
/ 422 engine
JackRobin said:
Hey guys,
Regards,
Jack Gawecki
800-277-6246
THANK YOU JACK!!- FOR COMFIRMING MY FINDINGS. I must have read the owners manual and parts manual, and engine specs. at least a dozen times and I could not find any difference other than the carb. and governor settings.
/ 422 engine #48
I thought there was an oil cooler in the 25 HP engine. So we can just change the carb and spring and up the horse power? Sounds real easy.
/ 422 engine #49
That is correct, I wasn't talking about upgrading from EH6X to EH72, the crankcase for EH72 25hp is diffrent than EH6X series.
/ 422 engine
Bob;
The 3 engines are the 18HP, 20.5HP, & the 22Hp. The 25Hp (EH72 ) is a whole different beast.
/ 422 engine #51
Beechwood said:
Bob;
I want the different beast.
/ 422 engine #52
JackRobin said:
Hey guys,
Regards,
Jack Gawecki
800-277-6246
Boy, I wish I'd laid in a supply of 22 hp carburetors before the 180 guys found out about this!! :D:D
/ 422 engine #53
Very interesting stuff, the little 180 has less weight, and for a couple hundred the hp can be upped to 22. Hmmmm seems the gap is closing somewhat.
Keen eye Beechwood. Nice catch.
/ 422 engine
AMEN TO THAT!
I'm cobbling up a couple of more engine tricks but I won't let the kitty out of the bag just yet!
/ 422 engine #55
Thanks!
You are right. I put the right data on paper, but switch things around when posting. The 22hp and the 25hp must have the same PTO pump.
/ 422 engine
Beechwood said:
AMEN TO THAT!
I received my mufflers today from UPS for my dual exhaust conversion.
Heres a list of things I'm hoping to accomplish by doing the carb and exhaust change outs.
1--Have some reserve horsepower for the wheel motors, pumps, etc.
2-- Add some performance.
3-- Have less restricted exhaust.
4-- Reduce or eliminate poping and backfiring when shuting the engine off ,by doing away with the OEM sq. tube manifold.
5-- Reduce the heat index in engine compartment.
6-- Reduce the noise levels.
I'll post more information as the project progresses.
/ 422 engine #57
Watch out Beechwood! There's a problem that can follow your modifications, which I learned when I made my 422 quieter (remember the Supertrap thread?).
The rattles from the engine cover become very obnoxious. Couldn't hear them over the original exhaust.
I've fixed the worst by installing some thick rubber pads on the brace that holds the tank, where the engine cover rattles against it.
Now there's just some residual rattle from the hinge end but I haven't figgered a way to sound-isolate them. The pin/socket is too small to put rubber bushings into. I might be able to put some more rubber on the box to where it'll get "pinched" when the cover is closed, but this is still in the "thought process" stage.
Just be ready to hear rattling noises you never heard before.
Phil
/ 422 engine #58
Phil
Phil, When I needed to quite the rattle from the hood of my 1445, I cut several pieces of tire tread, and glued them to the deck. When you close the hood now, the hood sits on the tire tread, and hood noise is gone. If you put some thin tread back near the hinges, It will put some pressure on the hinges, and I believe that will quite the hinge rattle also. Can't hurt to try.
/ 422 engine #59
I did the same thing right after I bought the PT, with a couple of large thick rubber washers. Now no rattles.
/ 422 engine #60
My hood doesn't rattle. There were two rubber pads for the hood to rest on from the factory. Of course, it could be the silky smooth running Kohler... ;)
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
2016 John Deer 5075E (A60462)
2016 John Deer...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
2008 Ford F-250 Pickup Truck (A61573)
2008 Ford F-250...
Flex King KM 7 Section V Plow (A63688)
Flex King KM 7...
