422 engine
/ 422 engine #51
Beechwood said:
Bob;
The 3 engines are the 18HP, 20.5HP, & the 22Hp. The 25Hp (EH72 ) is a whole different beast.
I want the different beast.
/ 422 engine #52
JackRobin said:
Hey guys,
Long time no see... I don't really have the time to read the whole 5 pages of this thread so from reading some of the posts, I just want to let the cat out of the bag on the whole EH63/64/65 hp questions.
The only differences on all three of these models are the carburetor and the governor hole setting. If you guys have any additional questions shoot them my way in this thread, I'll try to answer as soon as I can.
Regards,
Jack Gawecki
Subaru Power Products
Technical Support Dept.
800-277-6246
Boy, I wish I'd laid in a supply of 22 hp carburetors before the 180 guys found out about this!! :D:D
/ 422 engine #53
Very interesting stuff, the little 180 has less weight, and for a couple hundred the hp can be upped to 22. Hmmmm seems the gap is closing somewhat.
Keen eye Beechwood. Nice catch.
/ 422 engine
AMEN TO THAT!
I'm cobbling up a couple of more engine tricks but I won't let the kitty out of the bag just yet!
/ 422 engine #55
KMA said:
The Power Trac website shows the PT422 having the 8gpm/2500psi PTO. :confused:
I have one... :D how can we increase the power of the EH65 without affecting reliability? :p
Thanks!
You are right. I put the right data on paper, but switch things around when posting. The 22hp and the 25hp must have the same PTO pump.
/ 422 engine
Beechwood said:
AMEN TO THAT!
I received my mufflers today from UPS for my dual exhaust conversion.
Heres a list of things I'm hoping to accomplish by doing the carb and exhaust change outs.
1--Have some reserve horsepower for the wheel motors, pumps, etc.
2-- Add some performance.
3-- Have less restricted exhaust.
4-- Reduce or eliminate poping and backfiring when shuting the engine off ,by doing away with the OEM sq. tube manifold.
5-- Reduce the heat index in engine compartment.
6-- Reduce the noise levels.
I'll post more information as the project progresses.
/ 422 engine #57
Watch out Beechwood! There's a problem that can follow your modifications, which I learned when I made my 422 quieter (remember the Supertrap thread?).
The rattles from the engine cover become very obnoxious. Couldn't hear them over the original exhaust.
I've fixed the worst by installing some thick rubber pads on the brace that holds the tank, where the engine cover rattles against it.
Now there's just some residual rattle from the hinge end but I haven't figgered a way to sound-isolate them. The pin/socket is too small to put rubber bushings into. I might be able to put some more rubber on the box to where it'll get "pinched" when the cover is closed, but this is still in the "thought process" stage.
Just be ready to hear rattling noises you never heard before.
Phil
/ 422 engine #58
Phil
Phil, When I needed to quite the rattle from the hood of my 1445, I cut several pieces of tire tread, and glued them to the deck. When you close the hood now, the hood sits on the tire tread, and hood noise is gone. If you put some thin tread back near the hinges, It will put some pressure on the hinges, and I believe that will quite the hinge rattle also. Can't hurt to try.
/ 422 engine #59
I did the same thing right after I bought the PT, with a couple of large thick rubber washers. Now no rattles.
/ 422 engine #60
My hood doesn't rattle. There were two rubber pads for the hood to rest on from the factory. Of course, it could be the silky smooth running Kohler... ;)
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A61307)
2019 Takeuchi TL8...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2019 Big Tex T/A 16FT Utility Dump Trailer (A59230)
2019 Big Tex T/A...
2018 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A59230)
2018 Peterbilt 567...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
