4 1/2" angle grinder
/ 4 1/2" angle grinder #1
Bud
Near Pittsburgh, Pa.
Kubota B2400 & 1972 Economy Power King
4 1/2\" angle grinder
I looked at 4 1/2" angle grinders in Sam's and Cosco's. Cosco carries a Dewalt, and Sam's carries a Porter Cable. The price is the same, within a couple dollars. Which one is the better grinder, or is it just a matter of who's name you like best?
Bud
/ 4 1/2" angle grinder #2
Re: 4 1/2\" angle grinder
Bud:
Your looking at two of the current best power tool producers, so its really a matter of your choice in names.
/ 4 1/2" angle grinder #3
I have a one man shop. At any given moment I'll have four to six four and a half inch angle grinders.
The best to buy in my humble opinion is Metabo. They have a wrenchless change out system and they just seem to want to wear forever.
Right now I have a couple of Metabos, a dewalt, a milwaulkee, and a hilti.
The hilti costs as much as the metabo and I can see where it would be great for concrete work but it isn't really that great for ironwork. It's just awkward for me the way they've angled the head.
The milwaulkees just don't seem to wear for very long. But I do like their paddle handle over the other brands.
I've had dewalts that were good and some that were fair. Two notes on them. First and foremost is Home Depot carries two models. The cheaper one is for those who want an angle grinder and don't plan on using it. The more expensive one lives longer than the milwaulkee and is lighter and has a smaller head for getting into smaller places. But do check out the model numbers and make sure you're getting the heavier duty one if you're planning on using it. Otherwise you can save your money and run to Harbor Freight and spend a third the money for real trash.
I had a dewalt that took forever to wear out. This was not good. A bud had been using it and working at my shop and complaining about the safety tab. He was fighting it. So I let him remove it in a moment of almost fatal head up buttitis.
That grinder bit me more times than I can count. I have found the dewalts the best for cup brushes. I use cup brushes all day long. And take it from a scarred up old man, don't mess with the safety tab on the paddle switches.
If I was going to buy one angle grinder I'd look at what I'm doing with it. A lot of the good ones don't have variable speeds and they aren't that compact around the head. Also a wrenchless changing system is one of the handiest things to come down the pike since pockets on pants.
Variable speeds and a paddle on off switch is the cat's meow for cup brushing, polishing, and some grinding, detail kinds of work. But if you're just grinding and it's all about metal removal then those options aren't really important.
I do artsy fartsy with iron, wood, and rock. There are stones available for using on granite, bits that work like a chainsaw on wood and then your whole spectrum of blades for metal work.
The flap discs are the greatest things since syrup on pancakes for working metal. You can lean into the work and they remove metal as good as a regular metal disc without the same size of sparks. Then you can lighten the pressure you're applying and polish like you'd do with a sanding disc.
My welding supplier has a new metal disc that has three notches cut in the perimeter. What's so trick about it is you can see exactly what you're doing as you're doing it. It blows the mind to watch the metal go away as you're working it. The downside on these discs is their cost.
Probably the biggest mistake rookies make with angle grinders is also the most expensive. They're not aware that those sparks permanently scar paint and glass even at a distance. A wayward group of sparks across the paint job of the wife's car can be one of the most costly mistakes modern man can make.
/ 4 1/2" angle grinder #4
Enjoyed reading your narrative on the 4 1/2 inch grinder. Very helpful for my future purchase.
PJ
/ 4 1/2" angle grinder #5
Hi bud at my shop I have a dewalt have had no problem with the grinder had some minor problems with a drill we have a dewalt repaire shop around the corner they repaired it qiuck at no cost so maybe location of dealers would be helpful check for authorized dealers/repaire shops
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
New - Front mount rototiller
New - Front mount...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
