362 dash disassembly ?
   / 362 dash disassembly ? #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
I want to get into behind the instrument cluster on my Massey Ferguson 362 (1993).
I've pulled the top and side covers off, but can't for the life of my see how to drop the instrument cluster out.
The bottom half has numerous screws in the front of it, but the bottom half has all the levers and steering running through it, so pulling that out is no good.
The top half has the rev counter and indicator lights.
I've got a third party service manual, but it tells you how to rebuild the engine but not how to pull the dash apart.
Any suggestions would be welcomed.
Thanks, Shane
   / 362 dash disassembly ? #2
I bought a MF 362 Yesterday so I am not much help. But, I would like to know if you get any help and how your project goes.
   / 362 dash disassembly ? #3
Shane. I have a 362 and will be pulling my instrument panel out. Here is the description from my Manual. Instrument removal.jpg
I don't think it will be a rael probelm, bit fiddly but thats about all. I have a probelm with the FWD and Difflock warning lights not working. They share a common earth for the warning lights on the printed circuit board. If this board has burned or cracked a replacement is not available. I'll have to resort to soldering accross the break to get bthem to work. hope this helps.
   / 362 dash disassembly ? #4
Well I am now the "expert" on getting into the instrument system. Removal of the instrument binical is not as bad as i thought althopugh you may want to remove the steering wheel using a steering wheel puller for easier access. The rest of the disasembly is pretty straight forward.
Now the warning. if you are going to play around with the printed circuit there are two circuits on this board. One has a common +ve and one a -ve run. Best identify them before you run tests since you will burn out a copper run if you short circuit. Not a major problem as you can solder a wire over the broken bit.
I found one burned out globe for the FWD light but the Diff-lock light is still proving an issue. There is as resistor on this light and I suspect it is stuffed. I'm guessing this resistor is designed to detect when the diff-lock actually engages before th warning light comes on. I am going to loop over the resistor and see if the light comes on when I switch on the Diff-lock. If it does then I'll probably leave it work like that. CeeBee
2011 GMC Savana 10FT Box Van (A51692)
2011 GMC Savana...
PAIR OF FRAME MOUNTS FOR VACUUM PUMPS (A53843)
PAIR OF FRAME...
2006 Chrysler Town and Country Van (A51694)
2006 Chrysler Town...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
NEW Woods 6ft Finish Mower (A53473)
NEW Woods 6ft...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
